Please help me get her back on the road
I have TBI 350/4L80E that I pulled from a 95 GMC Vandura 3500.I am in the process of putting this combo in my 72 Burb.I have the complete wiring harness and ECM still attached to the motor/trans combo.This is where I need help.I can do all the mechanical stuff no problem.....the electrical is where I am going to be lost.Has anyone on this site done this swap before keeping the fuel injection and ele. controlled trans?If one of yall knows how to do this, or have done it, can yall please help me out.Is there a Faq thread for this?
72 Cheyenne Super LWB 350/350 Factory A/C Tilt/Posi White/Med Red/White(on the way) 72 Custom Deluxe Burb(Arizona truck)Nice interior Great patina Project Patina Azul http://67-72chevytrucks.com/vboard/s...d.php?t=467668 |
Re: Please help me get her back on the road
Anyone gonna point me in the right direction?Once I get the wiring under control, it will be on the road in no time.I thought I would have 15-20 posts by now telling me how to get this done.Dont let me down yall
72 Cheyenne Super LWB 350/350 Factory A/C Tilt/Posi White/Med Red/White(on the way) 72 Custom Deluxe Burb(Arizona truck)Nice interior Great patina Project Patina Azul http://67-72chevytrucks.com/vboard/s...d.php?t=467668 Last edited by Flint70step; 06-01-2011 at 09:19 AM. |
![]() Join Date: Feb 2001
Bump for you...
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
Rottenwood Garage Member
I did the exact same thing in my 72 Suburban. I used the running gear out of an 89 Suburban. What helped me was I used the entire harness front to rear and only patched in the gauges. Now...with that said....Im pretty handy electrically.....and I WILL NEVER DO IT AGAIN!
I didnt have many problems but it took forever! I had the wiring diagram from the 89 and the 72 side by side and I sat ther and crossed everything over. It ended up being about a day per circuit becuase i had to walk away after each one. If I were to ever try that again I woul;d save the hours and hours and find a pre-made harness for that application.
2004 Chevrolet Suburban C1500 2001 Chevrolet 2500HD Crew 6.0 1999 Harley Davidson Electra Glide 1972 Chevrolet C-20 Custom Camper "Dump Truck" 1972 Chevrolet C-20 Suburban "Big Green" 1969 Chevrolet C-50 Wedge Hauler "Leonidis" 1966 C-10 2x4 short fleet 327 4 speed "Race Truck" 1952 Plymouth Cranbrook "Rican" (my grandfathers) 1931 Ford Model A Coupe "Black Beauty" 1930 Ford Model A truck "Club Cab" 4x4 Rottenwood Garage and Speed Shop.....where everything must be racy! It's not just a hobby..It's a LIFESTYLE!!! Thanks for nothing Barrett-Jackson You cant fix stupid or teach accountability! Time wasters, looky Lous and tire kickers are everywhere! Last edited by 72freak; 06-01-2011 at 09:36 AM. |
#5 | |
72 Cheyenne Super LWB 350/350 Factory A/C Tilt/Posi White/Med Red/White(on the way) 72 Custom Deluxe Burb(Arizona truck)Nice interior Great patina Project Patina Azul http://67-72chevytrucks.com/vboard/s...d.php?t=467668 Last edited by Flint70step; 06-01-2011 at 09:46 AM. |
Beautiful Burb by the way
#7 | |
2004 Chevrolet Suburban C1500 2001 Chevrolet 2500HD Crew 6.0 1999 Harley Davidson Electra Glide 1972 Chevrolet C-20 Custom Camper "Dump Truck" 1972 Chevrolet C-20 Suburban "Big Green" 1969 Chevrolet C-50 Wedge Hauler "Leonidis" 1966 C-10 2x4 short fleet 327 4 speed "Race Truck" 1952 Plymouth Cranbrook "Rican" (my grandfathers) 1931 Ford Model A Coupe "Black Beauty" 1930 Ford Model A truck "Club Cab" 4x4 Rottenwood Garage and Speed Shop.....where everything must be racy! It's not just a hobby..It's a LIFESTYLE!!! Thanks for nothing Barrett-Jackson You cant fix stupid or teach accountability! Time wasters, looky Lous and tire kickers are everywhere! |
What did you end up doing for the gauges in the dash?There are a lot of wires I'm sure I wont be using in the Burb.How do I terminate these wires with out messing up the ecm?Do you have any pics?Do you still have the wire diagrams for both?Where did you fing the 89 wire diagram so I can find one for the van harness?I just got done pulling the under dash harness and fuse box from the van.72Freak,thanks for your help in advance
I have not used a stock vehicle harness with an electronic transmission. My guess is though, that when you boil it all down, if you use the modern harness complete that you will really only hook up power and ground. All the VSS, temperature, throttle position, MAP sensor, etc is all self contained in the harness. Since it is 95, you are still OBD1 so you don’t have to worry about oxygen sensors, fuel tank pressure sensors, and the like. You can use “old” sending units to drive original gauges and leave all that alone. You can look at jagsthatrun.com for info on how to get a mechanical speedo output on an electronic trans-or just have your speedo converted to electronic.
If you try to use the van harness complete and replace the truck harness, it can probably be done. You will have to change ignition switch wiring, can probably use turn signal wiring, have to move hi-low headlight switch, have to heavily modify heater and/or A/C wiring, radio no big deal, fusebox hole is different, you will need to have your speedometer converted to electronic and ammeter converted to voltmeter (the original shunt ammeter won’t handle high amps), headlight switch wiring in cab is same, dome light easily integrated. I would integrate the taillight harnesses together. The engine compartment on the lighting side, I would splice the truck front to the van harness. The engine harness on engine side is OK. The rest of the swap is like any fuel injection/OD trans swap, finding a place for the ECM, fuel tank and lines, trans mount, driveshaft, etc. Here is a post on a TPI swap, much of the basics are similar to a TBI swap. http://67-72chevytrucks.com/vboard/s...=239354&page=2
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project Last edited by MARKDTN; 06-01-2011 at 04:26 PM. |
#10 | |
![]() Join Date: Apr 2005
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
#12 | |
#13 | |
![]() http://www.painlessperformance.com/w...rchAll=Classic Cars
The harness you linked for me says its for 82-93.Trans:2004r,700r4 and other non-electronic.Do you know of one that would work with the 4L80E I have?The money does seem well worth avoiding frustrating days in the Texas heat.
72 Cheyenne Super LWB 350/350 Factory A/C Tilt/Posi White/Med Red/White(on the way) 72 Custom Deluxe Burb(Arizona truck)Nice interior Great patina Project Patina Azul http://67-72chevytrucks.com/vboard/s...d.php?t=467668 Last edited by Flint70step; 06-01-2011 at 10:00 PM. |
#15 | |
#16 |
To me this is a bit too harsh. I have done a number of FI swaps using stock harness, just never done one that controlled the transmission too or tried to use it to replace the stock harness. I'm willing to bet that if you took the whole harness and unwrapped it and just kept what was needed for the engine and transmission that you will end up with just power and grounds. I know this is the case on Ford stuff, and earler TBI van. I have a 3.1 Cavilier harness that I am going to modify if I ever do another TPI conversion. Just have to add 2 injector leads and move a few wires around from what I can see. If you are good with electrical stuff, I would see this as a challenge. If you do buy a harness, I would not buy a Painless. IMHO the fit and finish is less than adequate. I have used them for street rod type rewires and if you do your own wrapping and finishing they work fine, but they come to you with small nylon tie-wraps every few inches instead of loom. For a FI harness they also use smaller gauge wire than original. Just my .02
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
#17 |
~Rest In Peace~
i dont go near wiring without my fluke meter and test light with power and extra ground and jump wires and my buddy eric who is a genius at electrical
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
#18 |
I'm gonna do some research and see what I come up with.If I can find an aftermarket harness that fits my app. and is reasonably priced I may go for it.Until then I'll be on the lookout on this thread to see what yall may come up with.I really do appreciate all the input and advice that yall take the time to give.Thanks and keep the info rollin.I cant wait to get my baby on the road
#19 |
Looks like you can buy a Howell harness for the TBI/4L80E trans for $400. See http://howellefi.com/gm-tbi-products...sses-only.html
p/n H9395 at the bottom of the page They make a super quality harness and will work with you if you need custom lengths or want fans, etc. If you don't want to deal with the stock harness, then this is the direction I would go. I will concede that for $400 it may not be worth the hassle of taking a stock one apart.
#20 |
not enough hours in the day
Check out this TBI swap thread. http://67-72chevytrucks.com/vboard/s...d.php?t=317519
65 K-10 Short Step 68 C-50 70 K-5 85 K-10 & piles of spare parts |
#21 | |
#22 |
I spoke with a Howell tech this morning and I'm all smiles
