Old 06-01-2011, 06:53 PM   #1
steverino66
offset hole in the bed bolt washers
I'll soon be ready to mount the bed back to the frame after installing new wood. These 8 odd washers for the long carriage bolts presumably have the offset holes to keep things from wandering side to side…?
Question: is the best plan to use a flat cutting drill bit the same diameter as washer to provide a recess for washer and bolt, making a second small hole with the point of the bit at center of the washer in the process? (this wasn't specifically covered in the instructions I downloaded from Mar-K's site)
steverino66 is offline   Reply With Quote
Old 06-02-2011, 01:14 AM   #2
Captainfab
60-66 Nut
Re: offset hole in the bed bolt washers
Are you trying to make these washers, or are you wanting to counter bore the wood for the washer?
Old 06-02-2011, 02:03 AM   #3
argonaut
argonaut's Avatar
Sounds too me like he's wanting a good method to do the offset counter bore in the bed wood panels...
Jason M. @argonaut62
1972 K5 Blazer CST, Turquoise
1966 K20 Short Fleet Pickup, Big Ugly
1964 C10 Short Fleet, Gertrude
2001 Porsche 911 Carrera
1996 Ford Bronco XLT
1980 Jeep Wagoneer
2008 Honda CBR1000RR
2005 Honda RC51
1981 Honda CB750C
No dis-assemble Johnny Five! No dis-assemble!
argonaut is offline   Reply With Quote
Old 06-02-2011, 10:49 AM   #4
steverino66
That's right - sorry I wasn't clear; drill a small hole through the wood where the long bolt goes through the frame (at the square hole), then with a paddle bit, offset bore the diameter and slight depth of the washer, correct? -
anyone have pics (short step bed): will the washers center on the boards between metal strips?
Old 06-02-2011, 02:03 AM   #5
Dino Driver
Dino Driver's Avatar
I will be getting into this issue when I tackle the bed. I planned to use a forstner bit to make the counter sink and then use a paddle bit to cut the hole for the bolt.
Dino Driver is offline   Reply With Quote
Old 06-02-2011, 02:14 AM   #6
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
I always figured the offset was so the bolt didn't rotate when you were underneath tightening the nut.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 06-02-2011, 10:29 AM   #7
ChevySixty6
ChevySixty6's Avatar
I think the reason was so you could shift the bed around and line it up
to be straight with the cab.
Members i've met: LiLRed66
ChevySixty6 is offline   Reply With Quote
