Old 03-31-2003, 09:11 AM   #1
Purs
Got Big Block?
Purs's Avatar
Tach ?
How do you test a tach? mine seems to be dead. Is there a way to just see if the tach itself is dead? it's a factory 7k tach. (camaro) thanks.
"Experience is what you get when you didn't get what you wanted."
Purs is offline   Reply With Quote
Old 03-31-2003, 09:32 AM   #2
JimKshortstep4x4
Talking
The first test that you might want to do is with an ohm meter.
Test the positive and negative terminals for reading to case.
The next item that I would try is to ground case, hook 12v to power terminal, then with a volt meter measure negative meter to ground. You should be able to make meter read with this test.
Thse two test should at least let you know whether the tach works or not.
Jim
Old 03-31-2003, 12:31 PM   #3
dmec
dmec's Avatar
when you connect 12 volt, needle should go to zero. i also made up some leads and connect it to my dist an check operation before install in dash. i think that is best way.
dmec is offline   Reply With Quote
