Justified!
I'm looking at installing a Vintage Air unit. On their website, they say the same unit fits 60-72. From what I can tell, they use the existing heater controls.
I have none of any kind. And I don't see an option to buy the controls to add.... Everything that they show for the Sure-Fit kit is tailored for the 67-72 truck. I see nothing for the 60-66 truck controls. What is everyone using in their trucks? And pics please if you have any. Thanks, Chad
Chad 1964 GMC Fleetside Shortbed....350/700R4 tranny ![]() Last edited by 64GMCHorsepower; 06-04-2011 at 07:09 PM. Reason: I can't spell |
![]() Join Date: Oct 2009
Re: Vintage air? Who has it in their truck
not sure which year your truck is, but recommend take a peek at these places - they seem to be more stock control "user friendly". Don't get me wrong, VA makes some really nice stuff too - but, like you, I've scratched my head a little on the controls - and I kinda like what these places below offer. Anyway, just for your SA. Happy hunting!
60-63 http://www.classicautoair.com/60_63_..._Chevy_AC.html http://www.oldairproducts.com/catalo...120132108.html 64-66 http://www.classicautoair.com/64_66_..._Chevy_AC.html http://www.oldairproducts.com/catalo...120132064.html Edit: Oops, just noticed yours is a '64 - maybe someone else can use the 60-63 links. Anyway, I like these two places (Old Air and Classic Auto Air because their kits are very year/cab-specific. Last edited by jocko; 06-04-2011 at 08:37 PM. |
I went with the Gen IV unit from VA. My truck isn't done yet, but I've seen it in two other trucks - '72 and '65. Its a bit larger and you have to work a bit to get everything to fit but it looks good when done, and it blows like crazy. On mine, I installed the left and right vents on either end of the dash, and the center ones are mounted in the old control panels on either side of the radio. I actually welded plates in where the removable panels were. The electronic controls are going in the hole where the ash tray was. The Gen IV is all electronic so you don't have to worry about vacuum source. When it came time to get all of the hoses and fittings, their tech support (Mark) was great to work with, and he even sent me some pic's of his truck ('65) so I could how he installed his.
Steve 66 C10 Short Wide 51 1/2 ton (in storage waiting for 66 to be done) Pickups N Panels Club - Dallas/Ft Worth |
Here's a pic of the unit mounted under the dash. The bad part about the Gen IV is that is does hang down more than the surefit.
#6 | |
![]() Join Date: Nov 2007
TR
1965 C10 SWB Fleet Two owner LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880 |
Justified!
Jocko - Thanks for the links......I'll check them out
Tre - What year system did you use? I looked and they did not have a gen IV for my year truck...
Chad 1964 GMC Fleetside Shortbed....350/700R4 tranny ![]() |
Its not year-specific. You have to peice the parts together. I happened to run across a VA reseller that had done this a few times so he new what to order. I'll see if I can dig up the parts list and post it back.
I was looking at an "Old Air" unit myself as they seem to fit better and the controls look like the old factory ones.
#10 | |
![]() Join Date: Aug 2010
I have a Vinatge Air kit "in progress" on my 65 Suburban. Prev owner installed it, I need to finish the wiring and plumbing piece. Best I can tell from the manuals, it's their 75065-kit for 64-66 Chevy Pick-up, with the Pro-Line control panels. I'll post some pics later. Roy ![]() ![]() ![]() ![]() ![]()
1965 Suburban Waiting on Time and Money Last edited by RoyL; 06-05-2011 at 12:20 PM. Reason: add photos |
#11 | |
Can you post a pic or describe how you had to cut the firewall opening to allow for the two heater and ac hoses to fit through? I have the same ac I am installing in my sons 64. Thanks Glenn
Glenn Cumming, Ga (68 C/10 Fleetside LWB 307 (64 C/10 Fleetside Shorty Custom 350, with 73 donor parts aplenty) (2001 Porsche Boxster S - 168 MPH of fun) (2005 Chevy Avalanche Z71 1500) |
Vintage air 100% we have some killer deals on them.P/m or e-mail justin@scottshotrods.com
Justin |
#14 | |
Justified!
Wow! That is a nice install job, and very well documented.
#15 |
I have used Vintage Air in several builds. Their kits are complete and their customer service and tech support is top notch. I put a kit in a 71 and it fit nicely and was very cold.
I haven't done my 65 yet, however I have the inside unit that is a Vintage air and it was originally for a 34 or 37 Ford. It was free and unused from a close friend, so I will make it work. A Gen II compact should tuck up nicely under the dash. I put one in my 47. Here is a shot of the Compact II in a Model A: ![]() In this photo you can see the supplied bulkhead fittings for the cooling hoses. Dimensions are on Vintage Air's website so you can get an idea what you are dealing with. I have had such good luck with their products, I wouldn't even think of trying a different manufacturer. That Model A install is still blowing ice cold and the install is getting close to 10 years old. If you call them, you can pick your condensor, get the compressor polished or not, and pick your vents and controls. No need for a sure fit kit, the custom ones can be fitted much nicer. After making your choices, they supply the rest of the kit, including hoses, fittings, crimper if needed, dryer, etc. No need to chase parts, just a couple cans of freon, gauges, and a vacuum pump...... Last edited by wildearp; 08-06-2011 at 07:27 PM. |
#16 |
![]() Join Date: Dec 2010
I went with old air, I like the electronic controller no cables just plug and play, here are a few pics of what I'm doing
#17 |
Very nice and clean install you've got going there. Any pics of the unit installed in the cab? I'm curious how low it hangs below the dash and the quality if the unit overall. Thanks.
Keith SOLD - 1963 C10 Short Fleet 350/700R4 4/6 drop 1967 GMC Super Custom - Short Fleet COPO concept w/427 BBC T-400 w/Doug Nash overdrive 4/6 Drop, Buddy Buckets, etc... Frame Off (In Progress) I call it "Vulgar Display of Power" 1980 Silverado Original paint 49k Original miles 4/6 drop Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941 |
#18 |
Nice. That is gonna be a clean install.
#19 |
Vintage Air is currently developing a sure fit Gen IV for the 65 C10...I'm goning to wait on it
#20 |
towersddg, can you elaborate a little on how you installed the custom louvers - I like that approach and it's fairly inexpensive to do it (once I get past the mental block of choppin a hole in the dash for them). But I'm on my way considering a chopped a hole int he floor this morning for a shifter!
Just curious how easy (or not) the vents were to install. Looks great by the way. |
#21 |
Have an Old Air unit in mine, eight years old and still works good. One leak this summer but to be expected after this long.
#22 | |
#23 |
![]() Join Date: Dec 2012
I had a shop for 23 years Installed all types For my personal vehicles I use Old Air products
1946 car hauler 1948 surburban 1937 chevy sedan 1940 olds sedan (project) 1967 ss396 chevelle 1999 dually crewcab(24000 miles) |
#24 |
pictures uploaded!
#25 |
i want a center vent like that...does anybody make a repo of that or do you just have to luck into finding one in junkyard
![]() Posted via Mobile Device
live like you are dying ![]() |
