Old 06-06-2011, 07:23 AM   #1
HzSandman
73-74 grill & bezels to 79.
I want to fit the pre 79 style headlight bezels to my 79 C20. I have purchased a LMC speciality grill part #38-4035, but I'm unsure of what other parts I need. Is it just the bezels or do I require other mounting brackets ? Do I also need a new lower grill trim piece ?
I cant just go to my local junkyard as these vehicles arent very common in Australia. I do prefer the mid 70s headlight bezels than the 79 style...
HzSandman is offline   Reply With Quote
Old 06-06-2011, 10:12 AM   #2
bmchevy1979
bmchevy1979's Avatar
Re: 73-74 grill & bezels to 79.
it's a direct swap all you need is the lower trim and the bezels and everything bolts/screws in place of the originals as for the grill you will probably have to fab up some brackets if you can't find any in the junkyard
<Brandon>
1974 Chevrolet K5 Blazer 350sbc/SM465/NP205, dana44 front, corp 14bolt rear with 4.10s and a powertrax locker, custom rear bumper 400sbc in the works.
1981 GMC C1500 stepside 250i6, 3spd, 12bolt with 3.08s 2.5/4drop on 15x10 with 275/50r15
81 GMC C3500 cab-chassis dually with utility bed 350sbc, Sm465, 14bolt with 4.10s nv4500 getting ready to go in
1979 Chevrolet K5 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434096
1976 Chevrolet C10 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434195
bmchevy1979 is offline   Reply With Quote
Old 06-06-2011, 12:33 PM   #3
bigblock73
yeller
bigblock73's Avatar
You will also need the outer grill brackets, and center support and hood release assembly, all off a 73/74 truck.
bigblock73 is offline   Reply With Quote
Old 06-06-2011, 01:10 PM   #4
RandyP
Getting Old; Going Broke
RandyP's Avatar
I don't think he will Jeff, not with that aftermarket grille he is getting from LMC. It has a footnote that if you have a 73/74 and put this grille in, you have to buy the adapters for it. Otherwise I think it's a direct swap, only needing the lower grille molding and different headlamp bezels.
Why is every used 350 sbc out of a corvette?
There's only two things that excite a man, expensive toys and real expensive toys.
VEGETARIAN: That's an old Indian word meaning "I don't hunt so good."
When the going gets tough, switch to power tools.
RandyP is offline   Reply With Quote
Old 06-06-2011, 01:18 PM   #5
GCncsuHD
Charlie Daniels w/ a Tq Wrench
GCncsuHD's Avatar
I think you missed the part that he is installing that aftermarket billet grille from LMC. LMC actually states in the instructions that you need additional brackets to make the grille fit a 73-74 since it's brackets are farther back. It is made to bolt right on a 75-80.
Edit: oops, Randy beat me to it
ΜΟΛΩΝ ΛΑΒΕ
67 C10 Shortbed "Great Grandpa's Truck" I6 3 on the Tree 71k original miles 5.3 swap in the works
69 K5 Blazer-Family Beach Cruiser Project
78 K30 Dually Semi-Retired Fire Truck 350/SM465 35"s
SOLD01 2500HD ECSB 6.0 4x4 5.13's 8" lift 38"s
GCncsuHD is offline   Reply With Quote
Old 06-07-2011, 08:43 AM   #6
HzSandman
Just the info I wanted to hear, thanks. I'll order the new bezels and lower trim. No issue fabbing brackets if needed.
Old 06-08-2011, 06:32 AM   #7
HzSandman
Ok so i've just noticed LMC have 2 different part numbers for the upper grill moulding. Part number #38-3962 - 73 to 78 and part number #3839-63 - 79 moulding. Would I be right in saying I need 38-3962 or are both upper trims identical ? And its just the lower trim thats different ? Different length for uppers perhaps ? If anyone could confirm this that would be great as I have already purchased a new upper 79 moulding before I decided to swap to the earlier bezels. They look 1000 times better than the 79.
