06-06-2011, 06:04 PM | #1 |
"The Relapse" 78 Chevy Stepside
How's it going guys? I'm back with a 78 stepside I picked up yesterday afternoon. SOLID truck minimal rust, looking to get that fixed as soon as possible. I learned my lesson the first time around!
Anyway here it is: 1978 Chevrolet Stepside 250 cid Straight 6 3 Speed Manual Transmission (Death Trap) The previous owner's last drive: Right after it got parked in the driveway: My partner in crime loves it And after the Mavericks v Heat game this is what it looked like:
1978 stepside C10 build: http://67-72chevytrucks.com/vboard/s...d.php?t=468265 |
06-06-2011, 08:39 PM | #2 |
Re: "The Relapse" 78 Chevy Stepside
Need a better shot of the wheels on it now since the first ones had the hub caps (which looked cool). Good looking truck man & looking forward to seeing where you take it!
1977 Chevrolet K30 LWB Crew Cab 497HP Mast Motorsports 6.0L LY6 HO engine GM NV4500 5-speed, Centerforce clutch + NP205 D60 + 14-bolt FF w/ Eaton posi + disc brakes Skyjacker 2.5" full spring lift w/ Nitro shocks Custom paint + interior http://67-72chevytrucks.com/vboard/s...d.php?t=435722 |
06-06-2011, 09:06 PM | #3 |
Amazing the difference since you changed the wheels!
06-06-2011, 10:38 PM | #4 |
Thanks guys, I'll get some better pics of the rims tomorrow.
First thing on the list is getting the cab corner replaced. Cowl induction hood v8 swap 18" billet's and we'll see how wild this one gets
06-06-2011, 10:40 PM | #5 |
Might I suggest an upgrade to an LS truck motor given you're looking to do a V8 swap anyway. You'll be MUCH happier with it, even it you run it with a carb it's still a better engine than ANY of the older V8 designs!!!
06-06-2011, 10:43 PM | #6 |
That's the plan. I initially wanted a crate engine ls1 but I'm in the process of buying some land and got to adjust the budget a little. Might go with a used 5.3 or 6.0.
I like the idea of running a carb on an lsx, I've heard the peak horsepower goes up but the fuel injection is stronger throughout the power band.
06-06-2011, 10:48 PM | #7 |
I originally purchased an '08 LY6 6.0L out of a 2500HD that had less than 10k on it, but started wanting a different cam & springs so I just ordered a new one from Mast Motorsports already the way I want & making 497HP at the crank. The shop building my truck is now selling that motor since I won't be using it - it doesn't have the ECM, pedal assembly or MAF sensor however (does have the wiring harness though).
I went with the LY6 due to the better head design over the older engines as well as the advantage of the VVT feature. Any of the truck motors are great though! Pace Performance has a 4.8L carbed LS motor that's complete from carb-to-pan for $3k which is a pretty good deal - especially for a light 1/2-ton truck! |
06-06-2011, 11:04 PM | #8 | |
That engine you have sounds like a straight up beast! I'm mainly worried about the wiring aspect of the swap, I'm borderline retarded with wiring
06-06-2011, 10:58 PM | #9 |
WOW! You have great taste in trucks!
06-06-2011, 11:08 PM | #10 |
Just saw you avatar, haha! Thanks. This was my old one.......err new one before cancer took over it: Actually those are the rims I put on the 78
06-06-2011, 11:08 PM | #11 |
The Mast wiring & ECM is a little easier for installation & that's one reason I went with them. There are lots of companies though that sell LS harnesses that are pretty easy to install. Biggest thing is just ensuring adequate fuel flow & PSI.
06-06-2011, 11:12 PM | #12 |
Is this a complete setup? Just plug and play type of deal
06-06-2011, 11:20 PM | #13 |
Yep, for the most part - have to modify or change mounts, install the new pedal assembly & some other items, but pretty easy really. Mine didn't come with the fuel system (although you can get them) because we're using a new stock GM sending unit assembly for an '08 truck that fits in the gas tank they built. You can however just use the '87 sending unit assemblies in your tank & upgrade the pump.
06-06-2011, 11:23 PM | #14 |
Sounds simple enough. I'm going to start hounding around the junkyards for lsx engines right after i get that cab corner replaced
06-09-2011, 12:35 AM | #15 |
Home Built '87
Nice score!
Gordon 1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424 1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833 Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969 |
06-12-2011, 05:27 PM | #16 |
Thanks, it is I'm happy with it. It's getting tougher and tougher to find good, solid, build-able trucks for a realistic price.
06-23-2011, 11:09 PM | #17 |
Took me a little longer than I thought it would to get the pic, should have at least cleaned it
06-25-2011, 05:16 PM | #18 |
Nice. Subscriber from Corpus. Rust is a fact of life.
06-25-2011, 05:23 PM | #19 |
looks good with those wheels on it..
1981 C-10 (Pop's) 1978 Camaro 2006 Lacrosse |
06-27-2011, 02:22 AM | #20 |
Small world, I just got back from Corpus a few hours ago. Spent the weekend over there for the "Battle of the Bay" car show. Rust is the devil!!
Thanks, thinking of dropping it a little and cruising as is for the summer |
07-17-2011, 12:29 AM | #21 |
Might be picking up a new engine for it tomorrow
07-17-2011, 08:36 AM | #22 |
did you decide on 5.3 or 6.0?
07-17-2011, 12:59 PM | #23 |
What size are your wheels and backspacing?
1949 Five Window, 1973 Step Side, 2000 Z71 |
07-17-2011, 01:46 PM | #24 |
10-08-2011, 07:02 PM | #25 |
I like how the previous owner of yours took a sawzall to the rear bumper so it would fit. Gotta love that hillbilly ingenuity...
Can't seem to find a replacement rear step bumper for my old square, mine got bent from the previous owner colliding with something. Probably one too many cervezas while visiting the local fishing hole... I may just have to have this one re-straightened and replated if it's even possible. |
