06-07-2011, 02:09 PM | #1 |
???s for pontiac transplant
Hi everyone,
I am installing a pontiac 350 and turbo 350 trans in my 60 gmc and I was wandering which trucks would have the correct driveline yolk to fit a turbo 350 trans and my original driveline. the original auto trans and the turbo 350 are the same length, the truck is a short fleetside that had the 305 v6. I am not sure what the original trans is so if anyone has any thoughts on what it might be lets hear it, the idicator pattern on the colum is N, 1-4, 1-3, 1-2, space, R thanks, |
06-07-2011, 02:30 PM | #2 |
Re: ???s for pontiac transplant
Just take the original automatic slip yoke and put it on the 350, my 3 spd manual yoke would have worked on a 700r4 but I chose to buy a new one. They should be the same spline count etc. Kieth If it does not fit, find out what does at the driveline shop ..
06-07-2011, 02:52 PM | #3 |
You had the turbo hydromatic I think. But I also think it was possibly a transplant also.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
06-07-2011, 08:20 PM | #4 |
[QUOTE=Clyde65;4722695]You had the turbo hydromatic I think. But I also think it was possibly a transplant also.[/QUOTE
the hydramatics used 62 and prior were just plain old hydramatics cast iron case. turbo-hydramatic; the updated version (aluminum housing), known as a 350 or 400 ron |
06-07-2011, 02:53 PM | #5 |
Senior Enthusiast
It sounds like the original transmission is a 4 speed Hydramatic. If so you probably also have the rare and desirable factory transmission crossmember under the tail housing.
http://en.wikipedia.org/wiki/Hydramatic In my experience the same yoke fits the Powerglide, TH350, manual 3 speed, older model passenger car 4 speeds, and (I think) the SM420 if it has a slip yoke on the back of the transmission (some have a flange). Richmond and Super T10 4 speeds require the larger Turbo 400 yoke. There is a series number on the various yokes, but I don't deal with them enough to remember which is which. I'm not sure what yoke a Hydramatic takes, but it's probably the same as the TH350. I'd suggest to fit it in place and see if it works. And welcome to the forum! Last edited by markeb01; 06-07-2011 at 02:57 PM. |
06-07-2011, 07:26 PM | #6 |
Thanks for the replys, The original trannys tail shaft has fewer splines and is a little larger compaired to the 350 tranny,it would not fit my turbo 400 either. the original tranny has a special adapter for the v6 and the crossmember bolted to the bellhousing. it took a while to figure out how to seperate the two.
06-08-2011, 08:42 AM | #7 |
4spd Hydramatic should be coarse spline output shaft. TH350 is fine spline. You'll need to change the yoke.
What are your plans for the Hydro? Posted via Mobile Device
_____________________________________________ Ray All my life, I've been told I'm a "Bad Influence" |
06-08-2011, 11:26 AM | #8 |
"Where were you in '62?"
((((Transmission Specs ))))
http://67-72chevytrucks.com/vboard/s...d.php?t=390542 Online engine resources (casting numbers, calculators, etc.) http://67-72chevytrucks.com/vboard/s...d.php?t=382583
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. |
06-09-2011, 10:01 AM | #9 |
Thanks guys for the info on the trans. I read somewhere that some early gmc trucks came with a pontiac motor in them so i will see if I can find the type of flexplate to mate to the trans. It would be nice to be able to use the original trans if not I will hold on to both motor and trans so they can be put back in if wanted.
06-09-2011, 10:12 AM | #10 | |
Canadian built 6 cylinder '55 through '61 GMC's used the 235 and 261 versions of the Chevy 6. '55-59 Canadian built V8 GMC's never used the Pontiac engines. Instead, they came with 265 small block Chev V8's in '55, 56 and '57 (and into early '58) with the 283 Chev V8 becoming optional in '57 and the standard V8 in mid '58 through '67. In '62 the 327 and (1962-'65) 348-409 Chevy engines became extra cost options in various model Canadian GMC's. Beginning in '66, 396 and 366-427 Chevy big blocks were used as optional engines after the phase out of the 348-409 Chevies. Canadian built light duty trucks (under 10,000 GVW) never used the big U.S built V6's- they were simply rebadged Chevies and used the standard Chevy inline 6 or 283-327 small block (or 348-409 or 366-427 V8's in the heavy trucks), although the 401, 478 V6 and 702 V12 could be "special ordered "in the big (over 10,000 lb GVW) GMC trucks in Canada. http://en.wikipedia.org/wiki/List_of_GM_engines http://history.gmheritagecenter.com/..._Truck_History
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. Last edited by 1Bad62Pro/Street; 06-09-2011 at 10:14 AM. |
