Old 06-11-2011, 05:03 PM   #1
grs
Do you like where I put my radio.
Some one put small speakers in the dash. I put big ones in the back corners. What do you think of the place I put my radio?
grs is offline   Reply With Quote
Old 06-11-2011, 05:27 PM   #2
Cherub
Cherub's Avatar
Re: Do you like where I put my radio.
good but i think it may take up floor space
Cherub is offline   Reply With Quote
Old 06-11-2011, 06:26 PM   #3
broey
Square
broey's Avatar
Squarebody Syndicate
broey is offline   Reply With Quote
Old 06-11-2011, 07:11 PM   #4
RandyP
Getting Old; Going Broke
RandyP's Avatar
I'd get tired of stepping on it.
Why is every used 350 sbc out of a corvette?
There's only two things that excite a man, expensive toys and real expensive toys.
VEGETARIAN: That's an old Indian word meaning "I don't hunt so good."
When the going gets tough, switch to power tools.
RandyP is offline   Reply With Quote
Old 06-11-2011, 08:03 PM   #5
grs
Maybe I could hang it on a wire from the roof.
Old 06-11-2011, 08:13 PM   #6
1LowToy
I still kinda like my AM radio in the stock location. Best AM radio I've ever had cause it won't turn on.
1LowToy is offline   Reply With Quote
Old 06-11-2011, 08:16 PM   #7
Restrorob
The One And Only !!!
Restrorob's Avatar
Tie it to the steering wheel for easier station changes !
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
Old 06-11-2011, 09:56 PM   #8
grs
That is a great idea. I could put a cup holder on top of it.
Old 06-11-2011, 10:00 PM   #9
bigwheel15
bigwheel15's Avatar
Didnt wanna cut up the dash I see?
bigwheel15 is offline   Reply With Quote
Old 06-11-2011, 10:06 PM   #10
grs
Here is what some one did to the dash bezel. I am fixing it.
Old 06-11-2011, 10:45 PM   #11
firenuttz
2lo4me/ntlonuf/ntfstnf
firenuttz's Avatar
how did you do that to the bezel???
62 GMC swb fleetside~ project: still undecided
84 Chevy 4wd crew cab 8 inch lift and 37" goodyear h1 pulloffs, still rockin the old mans former plate 2LO4ME
65 chevy 1 ton panel~ bagged/bodied duramax plans slowly in progress...
02 Silverado cclb duramax~ sas'd "bro" truck with more rust than imagineable...
firenuttz is offline   Reply With Quote
Old 06-11-2011, 10:58 PM   #12
Corts60
Just here to tinker
Corts60's Avatar
Is that grip tape/non-skid material?
Old 06-12-2011, 08:33 AM   #13
grs
I went to a shop where they install radios, and bought a piece of abs plastic. It is 1/8th. inch thick. It is smooth on one side, and textured on the other. Made a template. Marked the plastic with a welders soap stone marker. Used a straight edge, and used a box cutter knife to cut it. Keep cutting till the cut is deep enough so you can snap the piece off. Then cut the corner, and trim it. Use a file to to shape it also. I will use small black screws to attach it to the bezel later.
Old 06-11-2011, 11:21 PM   #14
Pop's C-10
Pop's C-10's Avatar
2 words...zip ties :d
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Pop's C-10 is offline   Reply With Quote
Old 06-12-2011, 09:25 AM   #15
weaintscared
weaintscared's Avatar
Who needs a radio? All you need is a big block Chevy motor, nice size cam, & headers with Flowmasters ( Now That's A Tune ). LOL
weaintscared is offline   Reply With Quote
Old 06-12-2011, 09:42 AM   #16
West Texas Z
El Mero Mero Frijolero!!
West Texas Z's Avatar
Thats what I did.
West Texas Z is offline   Reply With Quote
Old 06-13-2011, 10:32 PM   #17
grs
Got the radio installed under the dash. And dash repaired.
Old 06-14-2011, 03:30 AM   #18
1974ChevyC10
Overworked and Underlaid
1974ChevyC10's Avatar
First the repair you did on the bezel looks really good.Second where did you get that under dash mounting kit for your radio that also looks good and would like to know where you got it so i can get something like that for my truck?
I'd rather push a Chevy than drive a Ford
The Beast-1978 C10 LWB
Red-1978 C10 LWB
(Uncle Mike)Michael Henry Millett 11/5/1957 to 03/08/2012
Gone but will never be forgotten-RIP
(Uncle Chuck)Charles Manning Gulbronsen Sr 1956-2012
Taken from us to soon but you will live on in our hearts-RIP
1974ChevyC10 is offline   Reply With Quote
Old 06-13-2011, 11:06 PM   #19
broey
Square
broey's Avatar
why didn't you just use the area deigned for the radio?
Old 06-14-2011, 12:31 AM   #20
Low84
Low84's Avatar
Yeah, I'm a little confused too.
1978 stepside C10 build: http://67-72chevytrucks.com/vboard/s...d.php?t=468265
Low84 is offline   Reply With Quote
Old 06-13-2011, 11:28 PM   #21
mdb
Should've just shoved it under the brake pedal, or are you scared?
mdb is offline   Reply With Quote
Old 06-14-2011, 07:49 AM   #22
OSE_NERO
I'll be having two radios in mine, seeing as though my original one still works, but I want to listen to my iPhone and CD's, so I'm debating on widening my ash tray and taking it out, since there will be no smoking in my truck, ever, and putting the secondary, aftermarket radio in there to tuck it away with none-the-wiser. Or I may just make my glove compartment deeper and put it there, but that's a hellofa distance to switch a tune. Any ideas?
1981 C10 Silverado Package, a.k.a Project Bahamut
OSE_NERO is offline   Reply With Quote
Old 06-14-2011, 09:08 AM   #23
West Texas Z
the repair looks good.
Old 06-14-2011, 09:17 AM   #24
1tonchevy
C35 Crew Dually
1tonchevy's Avatar
where did you get the new radio holder?
If it aint square, I don't care.
84 C35 CC Dually Project log...
http://67-72chevytrucks.com/vboard/s...d.php?t=414892
1tonchevy is offline   Reply With Quote
Old 06-14-2011, 09:25 AM   #25
GCncsuHD
Charlie Daniels w/ a Tq Wrench
GCncsuHD's Avatar
The dash repair looks great....but why did you drill into the dash below rather than just putting the radio back where it should go? I had a similar looking panel to cover the radio area and mounted the radio in that spot. Looked much cleaner IMO.
Any local audio shop should have them, I used one when I hid a radio under the dash of my 70 Chevelle.
ΜΟΛΩΝ ΛΑΒΕ
67 C10 Shortbed "Great Grandpa's Truck" I6 3 on the Tree 71k original miles 5.3 swap in the works
69 K5 Blazer-Family Beach Cruiser Project
78 K30 Dually Semi-Retired Fire Truck 350/SM465 35"s
SOLD01 2500HD ECSB 6.0 4x4 5.13's 8" lift 38"s
GCncsuHD is offline   Reply With Quote
