06-12-2011, 10:38 PM | #1 | ||
"I ain't nobody, dork."
Cracked Brake Line Fix
Went to change the oil in the truck today and noticed something I have missed for the last 5 years. The brake line that runs from the rear of the proportioning valve down to a flare union at the crossmember under the engine, was rubbing on my header. Not good. So I gently moved it out of the way and "boink" it cracked at the weak spot where it had been rubbing.
So I hop in the '94 and off to the parts store for some fittings and a 4 foot piece of 1/4" steel tubing. Here are a few pics of the process. I bent some of it by hand just to get it around things. But the two 90 degree bends I did with the tubing bender. First 2 pics are of the culprit. Third pic is the new line I bent. I even removed the "slinky" from off of the old tubing and reinstalled it on the new tubing. I'm assuming its to help keep it from rubbing the frame and the other tubing for the front brakes. Fourth and fifth pics are of the tube installed in the truck. Vacuum bled the brakes and good as new! I relocated the holding tab on the frame a little further up to help keep the vibes down and keep them in place. Very happy I found this in the driveway and not on the highway! I am soooooo glad I bought a quality tubing bender and a flare double flare tool as well. Gary
06-12-2011, 11:44 PM | #2 |
Hand Crafted C-10
Re: Cracked Brake Line Fix
Good Job! Brakes can be handy.
06-12-2011, 11:51 PM | #3 |
Impressive work
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
06-13-2011, 09:30 AM | #4 |
Good job on the brake line. They can be challenging to fabricate and install.
I found a brake line contacting a header pipe, too. The line looks OK (no obvious wear, surprisingly) but it was another item in a list of issues that made me decide to get rid of the headers and go back to ramshorns.
- Jim - My Daily Driver is a 1969 Chevrolet Custom/20 Fleetside 350/TH400/Eaton H052 4.10 and its Project thread is here http://67-72chevytrucks.com/vboard/s...d.php?t=456911 |
06-13-2011, 01:21 PM | #5 | ||
Thanks you'se guys.
Gary
