Old 06-13-2011, 12:02 AM   #1
72GMCDD
Four radiator swap now fan shroud doesn't fit
Wanting to see if anyone has ran into this or have a solution. I have a 72 gmc long bed with a 350 the owner before me installed a four core radiator and didn't install a shroud. Went to install the new shroud and the lower part of the shroud is about an inche off from the mounting holes. Does the core support have to been changed or do you have to modify the core support to allow it to fit?
Thank you
Donnie
72GMCDD is offline   Reply With Quote
Old 06-13-2011, 12:34 AM   #2
eagleuh1
eagleuh1's Avatar
Re: Four radiator swap now fan shroud doesn't fit
On my 68 there was a metal c channel spacer that went between radiator and shroud. It was about 3/4 wide. 4 core radiator as well. Don't know if thats what your asking though.
eagleuh1 is offline   Reply With Quote
Old 06-13-2011, 12:35 AM   #3
BlackTopMotors
I know this isn't a permanent/best solution but you can run some heavy duty cable ties and sinch em up tight if you need too get by.
BlackTopMotors is offline   Reply With Quote
Old 06-13-2011, 02:03 AM   #4
cwgreen1971
cwgreen1971
cwgreen1971's Avatar
I just put one on today and had the same problem, I was going to use spacers but instead just put some J nuts on the bottom of the core support and pushed it back tight and bolted it. Worked out just fine...
cwgreen1971 is offline   Reply With Quote
Old 06-13-2011, 09:08 AM   #5
72GMCDD
Thanks for the ideas this gets me pointed in the right direction!
Old 06-13-2011, 10:00 AM   #6
Boog
laying low
Boog's Avatar
The core support accepts 2,3 & 4 core radiators. The upper and lower brackets and insulators are different. I have seen 4 row radiator shrouds listed. I have a 4 row rad in my 69 and the shroud I have has about a 3/4" gap between the mounting pads and the brackets. As mentioned you can use zip ties for temporary as I have. Fab up some 3/4" spacers to mount it more solidly is a better idea. Cheaper than a new 4 row shroud if you can find one.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 06-13-2011, 10:25 AM   #7
Thealien
Thealien's Avatar
there are some clips on my 4 core that clip onto the support and hold the bottom of the shroud. Mine is a 4x4 but
i think the clips are the same??
they are factory clips btw
Old 06-13-2011, 05:02 PM   #8
chewychevy67
My 67 2wd had a 4 core rad and this is what was in between the rad support and the shroud. It is stamped very nice so it must be factory. I have seen the ones with the clips to.
chewychevy67 is offline   Reply With Quote
Old 06-13-2011, 05:20 PM   #9
Boog
laying low
Boog's Avatar
I don't know that i've ever seen one of those.
Boog
primer is finer
Old 06-13-2011, 06:31 PM   #10
FirstOwner69
FirstOwner69's Avatar
I just took the shroud off my '69 and a junker. Both had clips as well as a couple others in the junkyard. However, the '71s and '72s in the junkyard had different shrouds. I don't recall if they used the clips. I just bought some of these http://www.classicindustries.com/truck/parts/17117.html
FirstOwner69 is online now   Reply With Quote
Old 06-15-2011, 08:12 AM   #11
eagleuh1
eagleuh1's Avatar
ChewyChevy67, thats the spacer that I was talking about. Thats exactly whats on my 68.
Old 06-15-2011, 08:33 AM   #12
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
My 71 has the clips and its a heavy duty radiator.
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
Old 06-15-2011, 10:00 AM   #13
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
My original radiator and the replacement are both 4-row core radiators. The original shroud fit both without any issues, but two of the tabs on the shroud will have to be repaired to make it whole.
Seems there are different shrouds based on engine size and with/without AC. Anybody else know?
Member Nr. 2770
Old 06-15-2011, 10:09 AM   #14
Boog
laying low
Boog's Avatar
There were/are several different shrouds for our trucks. A quick check of Classic Parts lists 4.
Standard radiator, small block
HD radiator, small block
4wd radiator, small block
Big block
I'll check LMC later.
I have a 4 row in mine and a standard shroud will not bolt up. There is that 3/4" gap between the rad and the mounting ears of the shroud we've been talking about. A couple of guys have a factory looking spacer that came on theirs.
On page 117 of the LMC catalog you'll find the shrouds listed the same way as Classic Parts. Also note there are no spacers shown like the one above.
Could those above be from an aftermarket conversion maybe?
Boog
primer is finer
