Drag Racer
My 1983 Chevy C10's BRAND NEW look!!!!!
ok guys, i spend from noon to 10:30 pm Saturday, minus a 2 hr break and about 1 hr this morning doing a FULL drop kit on my truck. I used a Mcgaughys 4.5" front/6" rear drop kit. It consisted of spindles and springs up front as well as a flip kit out back. I still have to install shocks and do some other minor stuff before i can drive it, but its fine as im waiting on a shim for my starter anyway. Heres some pics of it finished. If anyone wants any kind of write up/how to pics i will do those in another thread.
Before: ![]() After: ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Sitting on Bump Stops - removed and not much change, probably will end up needing to C-Notch it ![]() ![]() ![]() ![]() for some reason this tire is MUCH closer to fender lip than other front tire, not sure if this is alignment issue alone or if i need to go back in and check stuff, i can BARELY get my fingers between tire and fender whereas left front i can fit fingers in there plus extra room ![]() ![]() ![]() ![]() ![]() Well guys, let me know what you all think of the outcome and any suggestions on that right front tire being so different from the other three would be awesome, i know i still need to istall all 4 shocks, but i doubt thatll change this issue any. also, my buddy says since i lowered it factory alignment specs are incorrect and i need new specs that fit new parts. is this true or not.
Zach Hall 1983 Chevy C10 R/T: .194 60': 2.322 330: 6.379 1/8: 9.803 MPH: 71.37 1000: 12.781 1/4: 15.314 MPH: 88.79 |
Master Procrastinator
Re: My 1983 Chevy C10's BRAND NEW look!!!!!
Sweet!!!! that made the whole truck, she's pretty
![]() 20 Duramax tow pig 68 2wd short stepper project 77 2wd short fleet beater 52 short project |
You should have chiseled off the rear bump stop bracket to give more clearance...then you just drill a little hole in the frame, and put in one of those little mushroom shaped bumpstops.
It's going to be more difficult to remove now that it's dropped, but not impossible |
Garage wrench
looks a TON better
Good job ![]()
-Adam 90 V1500 GMC Suburban 350/700R4/NP241..... 01 Saturn SL1 stock DD..... |
Truck looks good!
Go ahead and save for some 255/60 front tires. You will not be able to run those 275 for long on the front. I had them on mine and after I dropped it any little bump or dip in the road at speed and the fenders were chewing the sidewalls up. I only did the 2.5" spindles and it was eating my tires bad.
Paul '78 GMC Serria 15 Heavy Half. 361/NV3500/3.73. Former LWB NV3500 swap Trailing arm swap '98 ECSB Z71 daily driver -traded ![]() '03 burb. Family cruiser http://upstategmtrucks.com/ |
![]() Join Date: Jul 2010
perfect stance
1981 C-10 (Pop's) 1978 Camaro 2006 Lacrosse |
![]() Join Date: Dec 2010
Agreed - stance it's perfect just the way it sits!!!
1977 Chevrolet K30 LWB Crew Cab 497HP Mast Motorsports 6.0L LY6 HO engine GM NV4500 5-speed, Centerforce clutch + NP205 D60 + 14-bolt FF w/ Eaton posi + disc brakes Skyjacker 2.5" full spring lift w/ Nitro shocks Custom paint + interior http://67-72chevytrucks.com/vboard/s...d.php?t=435722 |
78K & 79C Jimmys
that looks great
nice stance yup
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
Diggin The SquareLife
u nailed it! jus need a sport bumper!! an remove hitch..
El Mero Mero Frijolero!!
Exactly my thoughts. Looks great!!!
My Toys: 1993 Ford Mustang LX 5.0 2001 Yamaha V Star 650 1984 Silverado > Build Page < |
That is exactly yhe stance I want for my truck, if and when I decide to lower it!
![]() There was a thread similar to this earlier in the week. Same situation. Look up Keith Seymore's recent posts. He gives a description of how the body/front end is put on at the factory. He also points to why one side could be closer to the tire than the other. He does an infinitely better job describing the situation.
'85 SWB Silverado |
Looks awesome man. Since you changed springs you will definately need an alignment by the way.
Drag Racer
hey guys thanks, hitch is already removed and anyone have any suggestions about the front tire issue i psted up? is that ALL alignment or is something else goofy with it?
I had the same problem with my 84 except the drivers side was lower than the passanger side.Its drove me nuts to the point where I took it back apart to ensure the coils the seated properly (which they were).I ended up chocking it up to just a simple chevy lean and the lowering made it much more noticeable. I ended up using the little trailer coil spring spacers that they sell at auto stores to level it and it aligned just fine. So you not alone. haha
#15 | |
Slugish
![]() Join Date: Jan 2005
#16 |
Resident of Here
Nice! Now time for a rear bumper...
~Bradley~ 2004 Black GTO LS2/T56 too much to list ![]() Miss having a truck ![]() |
#17 |
Chevys Kick A$$
Sweet looking good turned out great nice job
*HOODS is what I answer too* -'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold ![]() -'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit ![]() ![]() -'86 K5 Blazer Silverado 6.2 4" lift 35"s -'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's -'83 Monte Carlo T-Tops. 126,500 Original Miles -LATER ![]() I would rather push a Chevy then drive a ford!!
#18 |
Looks nice ! I'm lovin the red paint and the slots.
Jeramy '84 GMC project truck '85 Chevy 4X4 SOLD '07 Chevy Trailblazer SS 5th Annual SHPHC Car/Truck Show Pics http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT |
#19 |
The look is absolutely cool!
I have that "Chevy Lean" at the rear right corner and i heard that it is quite common to our style trucks! I like your waist jewelery! Volker
My little US vehicle parts business: http://www.thegearheaddepot.com/ Come have a look! ![]() ´81 GMC C 10, Spanish Red Last edited by moneyeater; 06-13-2011 at 04:07 PM. |
#20 |
The truck looks much happier now!
#21 |
nice clean truck man!.....mine had the same prob with one side lower than the other, apparently its quite common....you should get rid of the rear bumpstop completely, and unless you haul crap in the back or hit a huge bump it shouldnt bottom out!...I never had a c-notch or pipe notch for a long time.
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
#22 |
Great looking truck! I really like that red.
#23 |
Drag Racer
rubber bump stops are out but bump stop "bracket" is still in place, both front corners are same height, just one tire is closer to fender lip than other. Hitch is already off and will be ordering sport bumper this weekend from LMC.
thanks for all the comments guys!!!!! Keep em comin!
#24 |
Oh I see , sounds a little different than the problem I was having, I would like to see Keith seymours post on that , but anyway truck looks great and the bumper will just set it off
Posted via Mobile Device |
#25 |
Damn I've seen the same thread on 3 different forums now
-Mt Jasper 1998 GMC Suburban 2500 4x4~6.5 1987 Chevy K10 RCLB 4x4~6.2 81,000 Original Miles 1982 Chevy K10 RCLB 4x4~6.2 1983 Chevy C10 RCLB 2x4~6.2 1 Million Miles FERN MEADOWS REGISTERED SIMMENTAL CATTLE |
