Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 06-14-2011, 05:36 AM   #1
Blue Rat
Spring an shock setup on my 1971 C10 SWB.
Would like to have a little help with setting up the suspension setup on my C10. The engine is going to be about 550 HP BBC an a 150 shot. The rear end is a GM 12 bolt. The tranny will be an auto with a converter about 3500-4000 stall. Some street driving around town never any long trips. Track a few times a year.
Thanks for any help. Will be gone the next couple days to the swap meet at Petit Jean mountain.
Blue Rat is offline   Reply With Quote
Old 06-14-2011, 07:05 AM   #2
djracer
djracer's Avatar
Re: Spring an shock setup on my 1971 C10 SWB.
Are you keeping the trailing arms?
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 06-14-2011, 07:39 AM   #3
Blue Rat
Yes. For now, may change on the next engine.
Old 06-14-2011, 01:50 PM   #4
Super73
Super73's Avatar
You need total weight of the truck and axle weights before you can make any educated guesses for springs. You can't guess on weights either, as the type spring you should run is very long and with a lighter spring rate. Using a wrong weight will not give you the ride height you want.
Shocks are pretty simple, get adjustable ones, Rancho 9000's work well for the money.
Some do a coil over in the rear, others like myself use the factory spring location. Both can be made to work just fine. Again, axle weight and ride height need to be know to select a proper spring.
If you haven't already, check out the suspension 101 thread for a little more detailed info.
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 06-15-2011, 09:12 PM   #5
Blue Rat
I have been told to wait until the engine is in to set up the suspension. So, wait we will.
Old 06-15-2011, 09:34 PM   #6
djracer
djracer's Avatar
I agree totally.
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
