06-14-2011, 01:54 PM | #1 |
Will 72 C30 front disc brakes work on a 67 C20?
I have the opportunity to buy a 72 C30 parts truck with disc brake set up and was wondering if I would have a hard time to swap the disc set up to my 67 C20? What all is involved I guess is what I am asking.
If your not living for something, your dieing for nothing... |
06-14-2011, 03:51 PM | #2 |
its all about the +6 inches
Re: Will 72 C30 front disc brakes work on a 67 C20?
if it is a single rear wheel type front end, then go for it.
If it is a daul rear wheel, then the hub/rotor isn't the same, and I'm not sure if the spindle would be the same size or not. |
06-16-2011, 05:30 PM | #3 |
So this is it..... Think it will work?
06-17-2011, 06:44 AM | #4 |
Watch out for your cornhole !
The conversion is the same as a normal half ton conversion, just bigger. You can swap the entire suspension, or just control arms and brake stuff just like you'd do on a smaller truck.
06-17-2011, 06:56 PM | #5 |
You'd just unbolt the whole front crossmember and bolt it right back on your 3/4 ton.
Should be cake. |
