converting a 68' gmc 2500 8 lug front to a 1500 5 lug setup.
Is this just a question of springs, spindles and 5 lug rotors or is there somthing I'm missing? Any help would be welcomed! Its a super nice original truck,327, original paint, been in california its whole life so no rust pictures coming soon!
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: converting a 68' gmc 2500 8 lug front to a 1500 5 lug setup.
Differences:
spindles lower control arms rotors calipers steering linkage tie rod ends Give us a little more info on what you have planned and what parts you have. Total suspension rebuild? Lowering?
I just want to get this sucker down! Early classics has a custom spindle with a 2 1/2 '' drop that bolts right on and is designed just for this conversion.
Happy to be here
![]() Join Date: Mar 2000
Since you plan to lower it, do you also plan to go to aftermarket wheels? If so, you should look at the limited options available in 8 lug before you make your decision. Yes you can drop it with the ECE spindles, but then your wheel/tire selection is very limited.
#5 | |
You will also need to use 1/2-ton calipers, dust shields, and bearings.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 06-21-2011 at 10:27 PM. |
