HC8 3.21 Gears For Dana 70hd or 14 Bolt?
HC8 RPO 3.21 ratio gears....
Does anybody have info on what these came in? Production numbers? Standard on which trucks? Where I could find some? I want them for my 1987 R30 cummins conversion. I need a taller gear for the tire size I am running and expected cruse rpm. I have a 3.73 Dana 70HD right now. Thanks alot! |
Re: HC8 3.21 Gears For Dana 70hd or 14 Bolt?
most likely a diesel application. Very hard to find, another board had a member looking for a set, thinking he was looking for over a year, I think he ended up buying new, don't really remember.
I'd be easier to get a 4500 to swap in....
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 6” lift 1999 GMC Yukon 350/4L60 4" SAS |
I already have an 4l80e to back it up Ibut I like to travel ant high speeds.
Any Idea where he got the New gears? |
I can't even remember what site it was. Either CK5 or Pirate. Check Randy's ring n pinion, they might, Summit too.
Moderator
![]() Join Date: Oct 2008
I'd be careful of gears that long with big tires.
I have an 86 K20 with a 6.5 NA Diesel, 700R4, 31" tires (265 70 16 E) and, 3.73 gears. I turn 2300 RPMs at 80mph. With lower gears I'd run out of torque. The sweet spot on my 6.5 feels like its just over 2200 RPMs. Highway cruising is excellent even if it is an automatic. The Cummins BT may actually have the sack to push 3.21 gears but I'd wanna be real sure. GM built some 1/2 ton trucks with tall 2.73 gears and the TH700R4 for fuel mileage. They were dogs. |
A stock 6bt will have plenty to turn the tires with even less gear...
At the body shop.
" That didnt make it any newer " " Dont antique the equipment " |
I understand that the cummins want 1500 - 1800 rpm for peak mileage.
I like to cruse interstate at 75 mph (Midwest is mostly 65 speed limit). I will be using 225 70r 19.5" tires. |
#9 | |
Moderator
I'd call Randy's Ring and Pinion. You may need more than just gears to make this work. Info I found from Yukon Gear says they make 3.54 to 7.17 gears for the Dana-70HD axle... For the Dana 70 with a 5/8" Pinion offset (70, 70-U, 70 HD) you can get gears for the 4.10 carrier in 3.54 to 4.10 and 4.56 carrier in 4.56 to 7.17 More info states that the non 5/8" pinion offset housing can be found with (3.00 or 2.73 ). IDK how you would ID one. I ran some quick what-if calcs through my RPM spreadsheet. You may actually be one of those unusual cases that would be well served by using a Gear Vendors overdrive unit. 225 70 19.5 = 32" diameter. 4L80E OD gear is 0.75:1 with your present 3.73:1 axle gears you will turn 2,210 RPMs at 75MPH. 1,724 RPMs when you engage the 0.78:1 GV overdrive. 225 70 19.5 = 32" diameter. 4L80E OD gear is 0.75:1 . Change to 3.54:1 axle gears and you will turn 2,097 RPM at 75MPH. 1,636 RPMs when you engage the 0.78:1 GV overdrive. 225 70 19.5 = 32" diameter. 4L80E OD gear is 0.75:1 . Change to 3.21:1 axle gears and you will turn 1,902 RPM at 75MPH. That's not quite in your sweet spot and you loose some of your ease-of-launch with a heavy trailer that the shorter 3.73 gears give you. An Allison 1000 6 speed would get you where you want to be too... $$$$$ |
Using a GV is an option eventually but a costly one. I was looking for lower rpm crusing for a less bank draining price. I have issues with my project "expanding" already.
When did the 14bolt start to come out in Fleet side Pickup width? I have read on some of the d***e diesel forums the gus swapping to the 14 bolt to get the 3.21 gears and alot of the d****'s hat 3.54's from the factory. |
If I can get a deal on an complete axle that would be best thus trying to find a dually axle with the hc8 3.21's.
I have a dana 70hd and it looks like the 14 bolt is the only one with 3.21's so I need a 14 bolt dually axle. |
I have 3.21 gears in my 14FF. They are stock in my 83 Suburban C20 454.
I was surprised to see them when I opened the rear diff for the first time. |
A 6BT will have more than enough torque in front of a 3.23 or even a 3.08 rear end for what you want to do.
My Suburban listed in my signature is even geared steeper than if you used a 3.08 rear end and it does very well at high speeds. I mainly cruise at 60 mph for best fuel economy but it is definitely more peppy at 75 mph. I'm currently running 265/70/17 tires which are very similar in diameter to the 235/70/19 tires you plan on using. The NV5600 tranny coupled to a gear vendors gives me a final gear ratio of 0.57.
1990 ¾ ton 4x4 Chevy Suburban -Cummins Diesel - 12 valve - factory rebuilt -6 speed bullet proof manual transmission - NV5600 -Gear Vendors Overdrive - HX35 Holset Turbo -NP205 iron transfer case -3.73 gears -2" Lift |
![]() Join Date: Mar 2003
Well, being a 6 year old thread he may have made a choice by now. But 3.21 gear sets are available in the aftermarket by a couple of different manufacturers. Brand new set could run you close to 300.00 with shipping. Tallest 70hd gear available is a 3.54
#15 |
I picked up a good used set from evil pay a year or 2 ago. I am goint to stuff the 70hd in and get it back on the road then swap. I am tired of not driving it.
