Old 06-17-2011, 10:25 AM   #1
into69z
"brand new second-hand"
into69z's Avatar
what did you use to clean your fuses?
I am working on cleaning up my electrical harness, checking grounds and looking for bad connections etc. I can't afford to replace the harness and the one I have isn't all cut up, so I figure I would just check and clean all connections and grounds. One area I have questions on is the fuse panel-the area where the fuses are kept-those spring tensioned metal ends-has anyone attempted to clean these? I was wondering if using a q-tip with CLR or tarnex would work. I want to try with the fuse panel in-place. What are some of the things that you guys have done to do this?
Steve
69 3/4t custom camper
tilt,am/fm,speed warning,air gauge,buddy buckets,aux battery, big block,p/s,p/b,a/c
67 Camaro
96 Impala ss-sold
04 hybrid Honda-saving gas for the blue truck!:
b69:
into69z is offline   Reply With Quote
Old 06-17-2011, 10:59 AM   #2
TheSeeker
Re: what did you use to clean your fuses?
Ive used a q-tip and baking soda and water, just a little bit works fairly well, then Ill clean it up with a tiny wire brush. I dont know if its the correct way to do it, but I havent had any trouble yet XD.
TheSeeker is offline   Reply With Quote
Old 06-17-2011, 11:00 AM   #3
Roadmarks
Roadmarks's Avatar
I imagine TARNEX would be a good choice! A company I used to work for used it on relay contacts without a problem. When it drys, it leaves a white residue, so when you're done, be sure to clean the fuse block with alcohol and be sure that it is DRY before powering up.
best wishes,
Les
Roadmarks is offline   Reply With Quote
Old 06-17-2011, 11:05 AM   #4
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
This stuff...
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 06-17-2011, 11:12 AM   #5
70cst
70cst's Avatar
Originally Posted by GASoline71 View Post
This stuff...
Gary
Thanks for the info...
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 06-17-2011, 12:01 PM   #6
Papa-J
Papa-J's Avatar
This stuff...
Gary
You can also use Contact Cleaner, same stuff. You should be able to pick it up at any local electrical wholesaler or car/truck wholesaler .
1968 Chevrolet C10 - Needs lots of love
1996 Chevrolet S10
Born and raised on the east coast
Papa-J is offline   Reply With Quote
Old 06-17-2011, 03:35 PM   #7
into69z
into69z's Avatar
This stuff...
Gary
Thanks-that's what I was looking for-I'm not as flexable as I once was and half-blind to boot! I'll give it a shot................Steve
Steve
67 Camaro
96 Impala ss-sold
b69:
Old 06-17-2011, 03:41 PM   #8
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Never thought about doing that kind of job, but in retrospect, I have done something similar.
The edge contacts on PC boards (for instance) were best cleaned by using one of the erasers that you use for erasing ballpoint ink. Art gum may also work, but the ink eraser was a little more abrasive.
An electrical contact cleaner that leaves no residue and is not flammable is good. I know that WD40 will displace water and has been used many times, but I have a problem using anything that leaves a film and/or is flammable, on any circuitry that may see a spark. After using the contact cleaner, be sure to use good clean air...like the stuff used for computer keyboards, etc.
Member Nr. 2770
Old 06-17-2011, 11:43 PM   #9
LockDoc
The Older Generation
LockDoc's Avatar
I've cleaned a couple that had some rust issues with my Dremel and a small round stone. The stone is about the same diameter as a fuse, maybe just a hair bigger. Worked great.
LockDoc
Leon
Old 06-18-2011, 06:52 AM   #10
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
I must say that in all my years and all my vehicles, I've never had to clean my fuses. ??
Is this a common problem for some? Guess I've been lucky all this time and didn't know it.
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 06-17-2011, 12:12 PM   #11
GASoline71
GASoline71's Avatar
Best part about the one I posted the pic of... It leaves no residue, and dries very fast, so you can just plug stuff back together and go. No need for blowing parts with compressed air or wipey wipey with rags...
Gary
Old 06-17-2011, 12:55 PM   #12
mrein3
mrein3's Avatar
I bought DeoxIT at Radio Shack. It came in a bubble pack with a small cleaner spray and a small lube spray. I've been very happy with the results.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 06-17-2011, 03:02 PM   #13
cdowns
cdowns's Avatar
i spray real good with wd40 while i take my tiny cylindrical wire brushes and clean them up tthen with cotten swab apply a thin coat of dielectric grease to each contact b4 inserting fuses
when doing this make sure battery is disconncted
Old 06-19-2011, 07:38 AM   #14
'68OrangeSunshine
'68OrangeSunshine's Avatar
I've used Q-tips w/ Brasso on the contacts, followed up by tiny rolls of fine sandpaper twirled in the contact clips. Sometimes small modelers files, or Ignition files. Sometimes strips of Scotchbrite. Shots of Blue Shower to clean up. Silicon dielectric grease after the fact.
