Old 06-17-2011, 07:17 PM   #1
PortHeadlight
PortHeadlight's Avatar
Need recommendations to RAISE the the front 2"
Have a c20 Suburban with 350 and big wheels/tires. Need to RAISE the front two inches to prevent rubbing and level it off to get rid of the rake. Prefer not to use spacers that jam into the coils. And don't want to lower the rear. Seems that replacing with longer coils up front would be the way to go, but haven't found somebody (or a vendor) that can help. Any ideas welcomed! Thanks
PortHeadlight is offline   Reply With Quote
Old 06-17-2011, 07:49 PM   #2
formula_raider
Re: Need recommendations to RAISE the the front 2"
That it totally weird.....I just got onto this site to ask the same question. I used to be on hear all the time but finished restoring my 72 1/2 ton long bed a few years back so I havent been on here till today.
I had looked and looked while I was restoring my truck to find lift springs that would raise it up 2-3" with no luck, and like you I dont want to put those coil spacers inbetween the springs. I first tried putting in 3/4" springs thinking that they wouldnt compress as much and give me the right height....WRONG...it probably raised it up 3/4" an inch but it rode extremely rough. I ending up putting in urethane coil spring spacers in the bottom of the lower control arm where the bottom of the spring sits on stock 1/2 ton springs. It raised it about 3/4" but still needs another 2" in my opinion to take the rake of the stance of the truck. I just e-mailed Jeff from CPP, who builds alot of suspension products for our trucks, I asked him the same question as you. I will let you know if he returns any info.
formula_raider is offline   Reply With Quote
Old 06-17-2011, 08:01 PM   #3
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
aren't there something like spring pocket cups you can install below the spring to raise it?
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 06-17-2011, 08:13 PM   #4
formula_raider
Thats what I put into mine but it only raised it by like 3/4". They are urethane and made by Mr. Gasket part number 1285. They fit ok...but I wouldnt go any higher with this set up. A longer spring would be the ideal setup.
Old 06-18-2011, 12:10 AM   #5
N2TRUX
Happy to be here
N2TRUX's Avatar
Have you considered using lift spindles? I don't think they make an application for your year truck, but you can convert it to run 88-98 spindles. They make a 6 lug set up for them, and Google search indicates they also make them for the 2500 trucks too.
Read this to see how it can be done "73-87 2wd lift with 33x10.5x 18 Nittos"
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 06-18-2011, 06:37 AM   #6
LONGHAIR
The design of the control-arm style suspension will not allow you to increase the ride height much. It doesn't take much to hit the "droop" bumpstops, which are the limit of travel.
It's as simple as this...
Take a floor jack to the frame and raise it to the point where you gain the 2" between the top of the tire and the fender lip. You will probably not get much more travel than that anyway...but at least yo will be ale to see how close the upper A-arm is to hitting the bumpstop. The ride would be very harsh w/o this suspension travel, even if the springs didn't have to be stiff to get it up there.
As N2TRUX suggested, lift spindles would be a much better way to go.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 06-18-2011, 07:43 AM   #7
PortHeadlight
Thanks for all the quick posts and PRACTICAL ideas. Will also see if we hear from CPP. Thanks!
Old 06-18-2011, 08:19 AM   #8
7T2
Active Member
7T2's Avatar
What's rubbing, the tires? From the picture they seem pretty big for that vehicle. Some things just won't work.
1957 GMC Ambulance
1962 Belair Wagon
1963 C80 Truck Cab *FOR SALE*
1969 Chevy C10 Short Bed
1972 Chevy C10 Long Bed *SOLD*
1996 C3500 Dually *SOLD*
7T2 is offline   Reply With Quote
Old 06-18-2011, 10:20 AM   #9
pooz911
pooz911's Avatar
you can install big block springs to level it out. either flip the upper ball joint or install a ball joint spacer and remove the stock upper bump stop and install a shorter one. I added a set of limiting straps for insurance purposes so I don't stress the ball joints if the front suspension gets topped out.
www.cardomain.com/id/pooz911
pooz911 is offline   Reply With Quote
Old 06-18-2011, 05:10 PM   #10
LONGHAIR
I am not a fan of ball-joint spacers. They increase the leverage on the fasteners and big tires make this even worse. Having a failure in parts like this can be really ugly...
Old 06-18-2011, 08:34 PM   #11
pooz911
pooz911's Avatar
The truck has been lifted for 20 years....with no parts failures.
Old 06-18-2011, 10:49 PM   #12
texastrendz
Are the springs original factory? Maybe just a new factory spring may help. The factory springs after 30 years of service has had to of sagged some.
texastrendz is offline   Reply With Quote
Old 06-19-2011, 11:36 AM   #13
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
1 ton of BB springs is my guess??
John
1999 Toyota Tacoma 4x4
Old 06-19-2011, 06:46 PM   #14
tallic68
When I rebuilt my front suspension I replaced all the springs thinking it had some droop in it. After putting the new springs in I figured out there must have been some kind of leveling springs in her because it now has a good sized racke to her. She was level before and now she is not. Unfortunately I nolonger have the springs that were previously installed. I've been searching for another set of springs to level her out with no luck. I have been thinking about 3/4 or 1 ton BB springs, but don't have the money to just throw away if they don't work. I'll be watching this thread to see what comes about.
tallic68 is offline   Reply With Quote
Old 06-19-2011, 11:37 PM   #15
pooz911
pooz911's Avatar
if you have a small block, installing big block springs will level it out. It will raise the front end to where the stock upper bump stops will sit against the crossmember.
Old 06-21-2011, 10:42 PM   #16
formula_raider
Everyone....I got word back from Jeff Norton from CPP about taller springs and I quote "To answer your question , no we don’t make those but I have seen on ebay this guy who sells aluminum coil spring buckets that raise the vehicle. Check him out as it n=might be what you are looking for. Thanks"
Old 06-21-2011, 11:40 PM   #17
formula_raider
pooz911....where did you get your ball joint spacers. I cant seem to find them anywhere for our model year trucks? Do the rancho springs you put on your truck contribute to your lift or are they just stiffer stock length springs?
Old 06-22-2011, 12:12 AM   #18
pooz911
pooz911's Avatar
A buddy of mine who had a shop in Burbank, Ca was making them. He shut down the shop and went back to working for the movie studio's a few years ago. I have seen spacers on the web from Truckn suspension and others. The Rancho springs and spacers are in the catalog for a 73-87 truck. My '71 3/4 ton is the same. Using big block springs and running a small block will give some l ift but will ride a bit harder because the springs have a higher weight rate. I actually like how my truck rides....it rides like a truck!!!!
