Old 06-18-2011, 08:28 PM   #1
DnvrJay71
DnvrJay71's Avatar
Topper Bolt size?
Anyone know what size the bolt is that holds on the double wall fiberglass top?
When i took mine off, a couple of the bolts sheared off and a bunch of the rest were pretty rusty. I couldn't find anything to match at the local hardware store.....
DnvrJay71 is offline   Reply With Quote
Old 06-18-2011, 09:51 PM   #2
Thealien
Thealien's Avatar
Re: Topper Bolt size?
If you are asking about the ones that go up through the bedsides and into the top I "think" they are 5/16-18. Someone else should be along shortly to confirm or?
I put neversieze on the bolts so they will be removeable next time.
Old 06-19-2011, 03:22 PM   #3
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
You should be able to clean up the rusty ones with a tap. Mine were so far gone I had to replace them all. I went with wood 2x4's cut down to fit and then put 3/8-16 brass inserts in them to bolt down with.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
bolt sizes, fiberglass top
