Old 06-20-2011, 11:00 AM   #1
48richard
48richard's Avatar
Factory Tach Question
I am putting together a tach (and clock) dash using a Camaro tach. The Camaro tach has white numbers on the face. My question is - does a factory tach have any numbering painted on the face, or is it all on the lens? My thinking is if the factory numbering is all on the lens, and if the sweep of the tach is the same, which I believe it is, I could paint over the white numbers on my Camaro tach face, use a factory tach lens, and end up with the correct green numbering.
Thanks.
1971 C10 Longbed, 350/TH350
48richard is offline   Reply With Quote
Old 06-20-2011, 02:07 PM   #2
leddzepp
Moderator
leddzepp's Avatar
Re: Factory Tach Question
a factory tach has no numbers printed on it...the numbers are printed on the cluster lens
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 06-20-2011, 10:42 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I doubt you'll get away with just using the truck numbers on the lens... truck tachs only go to 5000 ROM, where camaros go to 7 if memory serves.
Old 06-21-2011, 12:50 AM   #4
Dave
DND Trucks
Smile Re: Factory Tach Question
There was a entire thread a while back dedicated to installing the camaro tach in a stock truck instrutment panel. Maybe someone knows where it is.
Dave is offline   Reply With Quote
Old 06-21-2011, 10:14 AM   #5
48richard
48richard's Avatar
Thanks, guys. There are several good threads about Camaro tachs, but the color of the numbering was not mentioned. If the factory tach only goes to 5k, then it looks like my idea won't work out. I guess if you go with the low $ option, you can't expect it to look perfect. Not bad, though.
I'm also putting in a quartz clock from a 80(?) truck, but with a 73 face grafted on to get the numbering font closer. I'll post a picture when I'm done. Total cost so far is about $40.
Old 06-21-2011, 10:29 AM   #6
ls1nova71
ls1nova71's Avatar
The '73 to '77 clock face makes the quartz clock look 1000 times better in my opinion, it matches the cluster better than the newer face. This is the one I put in my last truck.
ls1nova71 is offline   Reply With Quote
Old 06-21-2011, 10:33 AM   #7
48richard
48richard's Avatar
Yup - that's the same face that I got. Worth the trouble to swap the faces, I think.
