06-20-2011, 11:41 AM | #1 |
been here longer than Liz
changing wheel bearing
Gotta change the pass side wheel bearing, might as well do the drivers side while I'm at it. A buddy said to change the rotors at the same time so you have a new race. Looking at parts on rockauto, is all I'll need the rotors and the bearings? I've never done this repair before, so advice would be appreciated. This is on the 89 K5.
~Greg~ Mac's Garage '87 SWB 6/8 drop "Piso" '08 CCSB Silverado DD the departed '89 GMC K5 Jimmy 4x4 "Rusty Nuts" '77 Chevy K5 Blazer 2wd '83 Chevy stepside "You get what you pay for" - Mike 'swervin ervin' Ervin |
06-20-2011, 11:58 AM | #2 |
Re: changing wheel bearing
I'm not sure if the bearing race comes in new rotors . You should get a new race with the new bearing
06-20-2011, 12:16 PM | #3 |
Master Procrastinator
there is an inner bearing and dust seal, outer bearing, washer, castle nut, cotter pin and dust cap, new rotors for the price are worth while and the race is machined into them, I am just installing this setup today myself on my 68 which came with the 73-87 upgraded setup
My Buildhttp://67-72chevytrucks.com/vboard/s...d.php?t=395506 20 Duramax tow pig 68 2wd short stepper project 77 2wd short fleet beater 52 short project |
06-20-2011, 01:23 PM | #4 | |
06-20-2011, 07:13 PM | #5 | |
06-20-2011, 07:46 PM | #6 | |
I would definitely look into this noise. It will be far more costly if you tear something up. If it is just brakes, which is more likely, they can wait a few days.
If the noise really is the wheel bearings....stop now. A bearing that is making enough noise that you can hear it in the cab is hurting badly. It will get worse quickly. This is doubly important on a 4x4. If the bearings are worn enough the allow the wheel to tilt on the spindle, it can destroy the inner workings of your lock-out hubs. BTW a brass punch is the best way to drive the races out. There is a cut-out area in the back side of the machined area where is fits just for that. You may need to clean some grease out of the way to see them though. It's a fairly deep reach to the inner one, from the front side. You are going to need a spindle-nut socket too and probably some snap ring pliers, depending upon which type of lock-out hubs you have.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. |
06-21-2011, 01:34 AM | #7 |
look at me all excited over my own junk I overlooked the main point of the problem, sorry I'm on a 2wd myself
06-21-2011, 07:43 PM | #8 |
06-20-2011, 12:16 PM | #9 |
~Rest In Peace~
always use a new cotter pins ,is my advise
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
06-20-2011, 01:44 PM | #10 |
If the rotors are original I would change them just to be safe. They do come with races, but they are pressed in not machined. If you are not sure of the age have the auto parts store check them. If they are good, get new bearing and races only.
06-20-2011, 02:00 PM | #11 |
If the rotors are flat and within spec, changing them is a waste of money, IMO. Rotors are a consumable (slowly, if the brakes are properly maintained) part that have a very simple job. The races are inexpensive and are designed to be replaced without replacing the rotors.
Randy Summers Never brake in the learning curve! 1984 GMC Sierra project truck http://67-72chevytrucks.com/vboard/s...d.php?t=446737 |
06-20-2011, 02:48 PM | #12 |
my mistake, just had a look at mine and I stand corrected definietly pressed in
06-20-2011, 02:22 PM | #13 |
Ok, he made it sound like if you had to replace the race and not the rotor, it went outside the typical shadetree mechanic capabilities. No idea on the rotors, just thought for the price and knowledge of condition I'd change them anyways.
06-20-2011, 02:52 PM | #14 |
You can knock out the old races from the opposite side with a screwdriver and hammer. The new ones can be put in with a press but it is not necessary. Use a wood block to protect the edge and tap the new race in until flush. Then place the inverted old race on top of the new race and tap it in until fully seated. The old race will seem stuck at first but can pried out quickly with a screwdriver.
There are other ways to do it but this works well for me. If you decide to replace the rotors you will want to install new brake pads. Posted via Mobile Device
Randy Summers Never brake in the learning curve! 1984 GMC Sierra project truck http://67-72chevytrucks.com/vboard/s...d.php?t=446737 Last edited by sumran; 06-20-2011 at 02:57 PM. |
06-20-2011, 03:29 PM | #15 |
Getting Old; Going Broke
If you're worried about doing it Greg and need to practice on one... I'll buy the parts and you can practice on my 79.
btw, thanks again for the tires! I forgot about the rocker thing, let me know if I need to order that for you.
Why is every used 350 sbc out of a corvette? There's only two things that excite a man, expensive toys and real expensive toys. VEGETARIAN: That's an old Indian word meaning "I don't hunt so good." When the going gets tough, switch to power tools. |
06-20-2011, 03:36 PM | #16 |
Thanks again guys. I think I'll just replace several things at once to get them updated. Side question - the pass bearing is now squeeling, how bad is it? Can it wait til this weekend or does it need to be done ASAP?
Randy - thanks for getting them out of my driveway! No hurry on the rockers, can't do anything with them for a while anyways.
06-20-2011, 03:39 PM | #17 |
bow bad is the noise? have you inspected the brake pads? usually in my experiences the bearing will howl more than squeal, and once it starts it's doesn't take long to grenade, the brakes however find ways to squeal quite often from even road debris
06-20-2011, 05:33 PM | #18 |
Maybe it's a howl, not sure. It's intermittent, mostly at speeds 35 & below. I haven't inspected the brakes. I work 7 days a week this time of year, so I don't really get into anything unless I have to. If I need to change the bearings tomorrow night I will, if not I'll wait til this weekend when I have a little more time.
06-20-2011, 08:15 PM | #19 |
Don't use a screwdriver, you might scratch or nick the surface the race goes in.
Harbor Freight has a seal installer/ remover tool that does the trick, and it helps you drive the new race in, nice square and easy. My 2wd 1/2 ton '78 had nice rotors, but i wanted to replace the bearings when I lowered it, because the old bearings looked like they had taken on water at some point. http://www.harborfreight.com/10-piec...set-95853.html Best $30 bucks you'll ever spend. |
06-21-2011, 10:35 AM | #20 |
No noise at all yesterday evening or this morning.
Yes, it is a 4x4.
06-21-2011, 10:54 AM | #21 |
78K & 79C Jimmys
i had low speed noise come from the front hubs
goes away higher speeds or the squealers on the pads
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
