Bag Pressures
Hey guys, I have got my truck on the road and I am trying to setup the air suspension. I have a ride height setting on my controler, but not sure what pressures to set it at.
What pressures are you guys running at ride height in the front and back?? Thanx Trevor
1968 short box stepside. 2007 5.3L 4L60, tuned w/EFI Live 2005 Silverado bucket seats. Dominator 2600's all around. Porterbuilt tubular control arms. Magnaflow 3" dual exhaust. |
Re: Bag Pressures
Decide what height you want and that will determine your pressure.
Re: Bag Pressures
Hey Dave......... I had the front at 50-60psi and the rear at 30ish. It pretty high even at that pressure. Wasn't sure if the pressures should be higher.
It goes pretty good by the way.... When you coming down soo we can go for a rip...... Posted via Mobile Device
Re: Bag Pressures
I only have front bags and do it old school with schrader valves LOL so I don't know the pressures. I just use a tape measure off the bumper bolts to set ride height LOL. Next time I'm home I'll check my pressure.
When are you coming up to Castrol to flog it? Any videos? |
low n' slo
![]() Join Date: Mar 2009
Re: Bag Pressures
pretty much what he said. lower your truck a good ride height your comfortable with, and set it. your numbers sound about average..
any pics of the truck? ![]()
67 1/2 ton Suburban - Project DRGNWGN. Build thread ![]() -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
Re: Bag Pressures
tk's awesome truck...
Re: Bag Pressures
That's a nice truck! I run about 70 in the front and 30 out back.
#8 | |
Re: Bag Pressures
I know on mine anything less than 30 in the rear & it wanted to bounce much more vs. between 30-35psi.
low n' slo
Re: Bag Pressures
clean truck!
Re: Bag Pressures
what bags are you running? There are a few huge misconceptions with air suspesnion 1. Being you can ride at any height which is not the case air springs/ bags do have a manufacture suggested ride height where they are designed to be used at taking it bellow or above that can result in poor ride quality, bad handling characteristics, and premature failure. Actual presssure will vary from truck to truck, car to car, determined by the over all weight which can be effected by motor and accessories on the vehicle. Also having a vast window like no less that x and no more than x is wrong 5-10 psi on certain bags and leverage ratios can change the height dramatically so when setting up your air springs make sure the bags are set up at the proper height at ride height.
2. the beauty of air not only do you have the adjustability of height but also spring rate you can change the pressure now depeding on the vehicle between 1-5psi with out effecting the height but changing the spring rate and by doing so you can dial in the ride quality you want.... Let me know what bags you are running and I will get you the specified height they need to be at at ride height from there you air them up to what ever it takes to get it there 60-or 160 it will not make a difference as long as its at the manufactures suggested height, the spring rate is determined by volume not pressure, and pressure is based on weight... hope this helps. Last edited by tech@scottshotrods; 06-21-2011 at 11:39 AM. |
#11 | |
VA72C10
![]() Join Date: Mar 2008
Re: Bag Pressures
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
needs more $$$
Re: Bag Pressures
I'm not trying to steal this thread, but when the OP gives his bags, can you also give this info for 2600 DOMS on all 4 corners? This would be great info!
1970 2wd Blazer |
Re: Bag Pressures
not jacking the thread at all.... I will see what i can get from airlift and pass the info along... I am a firm believer in air suspension but see it done sooooo wrong way to often
![]() Join Date: Nov 2010
Re: Bag Pressures
^x2 thanks for the info! i didnt know there is a specific ride height for air bags
2003 Serria K1500 1998 Camaro 1964 C10 long fleetside bed, small back window, 3 on the tree 1964 C20 custom cab, long fleetside bed, big back window, 4 on the floor Disclaimer- anything posted is only based on my personal experience, opinions, and advice given by others. There are no implied or written warranties or guarantees with anything posted on this website. |
#15 |
Re: Bag Pressures
what I like comparing it to is a coil spring, reason is people forget thats what an air bag is a air spring. Just like a coil when heated or cut it will change the height but it also effects the spring rate and in the end the ride quality. I would love to say air suspension is the cure all for clearance issues etc. but it is not it too has limitations. Thats why you will hear some times that "my bag just blew" or "my car rode like crap" these are usually the case when some one is not familiarized with air suspension, installs a kit and expects it to solve any clearance issues or they dont understand the perimeters of the air spring it self.
#16 |
Re: Bag Pressures
Wow............... Missed a few posts.. Lol
I am running air lift Dominator 2600s all around. Just to show you I took some pics. First pic is with 55psi in the front and 40-45 in the rear. The second is with 65-70psi in the front and 40-45psi in the rear, and i think it is way to hi at 70psi. I had it out on the hi-way with 50 in the front and 30 in the back. At 100km/h every bump I hit the truck was all over the road. Keep in mind this is without an align too.
1968 short box stepside. 2007 5.3L 4L60, tuned w/EFI Live 2005 Silverado bucket seats. Dominator 2600's all around. Porterbuilt tubular control arms. Magnaflow 3" dual exhaust. Last edited by tk-mpl; 06-25-2011 at 12:28 AM. |
#17 |
Re: Bag Pressures
What drop are the spindles? This was my old 68 beater. The rear pressure was @ 30psi unloaded & 60psi w/the trailer hooked up.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 06-23-2011 at 03:25 PM. |
#18 |
Re: Bag Pressures
I know the Dominator 2600 bags get a ton of lift and not sure how much R&D Airlift has done on the spring rate vs. height vs. pressure I'm on hold hell now to get some answers..
I know Gumby the shop truck at air ride and the White C-10 require 85-95 up front Gumby was a straight six and the white truck had a SBC in it, the rear required 45-50 and this was with Fireston 224C bellows with tubular upper and lower arms and the bolt on rear kits... I will report shortly after I find the proper info on the Doms. The Dom 2600 should be driven between 6.5"-8" at ride height so when setting up your suspension make sure you have adequate space between you bracketry to accomodate this. Last edited by tech@scottshotrods; 06-23-2011 at 04:20 PM. |
#19 |
needs more $$$
Re: Bag Pressures
Thanks, jon!
SCOTI, that's the 1st time I've seen a pic of your 68...That's an awesome "beater" you go there!
1970 2wd Blazer |
#20 | |
Re: Bag Pressures
But, some of it's parts & ideas are where my 'Recycle' project came from. I have a guy that loved it back in the day that wants to buy it w/the Dropmember it had in place. Still debating....
#21 |
Re: Bag Pressures
Scoti, that is wicked........ I bought 2.5" drop spindles from CCP years ago..... I hope They are 2.5" drop cause that is what I wanted!!!!!
1968 short box stepside. 2007 5.3L 4L60, tuned w/EFI Live 2005 Silverado bucket seats. Dominator 2600's all around. Porterbuilt tubular control arms. Magnaflow 3" dual exhaust. Last edited by tk-mpl; 06-25-2011 at 12:27 AM. |
#22 |
Re: Bag Pressures
You listed your various pressures used earlier for each of the pics. Try the pressures again & measure the bags installed height @ each specific pressure & see where you're at vs. the mfr's recommended 6.5-8" 'ride' height.
#23 |
Redefining LowBudget
Re: Bag Pressures
Jon right on!! good info
MY TRUCK...BB Caddy cupped stock LCA and in place of the rear springs my guages are marked at 55 psi front and 30 ish rear...I get good ride and stance...I think the secret is to get your bags to ride in the middle of the baq and good shock set up...I have monroe 5758??? ( look for a 51 chysler front shock) in front in the stock location and stock rear shocks with the top and bottom mounts flipped to keep the travel and angle correct.......... All that being said I think there is some shock work to be done but for what I use it for ( everything from towing/hauling to ocational drag racing it works on my budget
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. ![]() Mikes Sandwich Fair Run OCT 8th 2011
#24 |
A guy with a truck
Re: Bag Pressures
Have you shortened your front cups? How are the rear bags mounted?
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
#25 |
Re: Bag Pressures
Yes the front cups are cut down, I think they are 1-1.5". The rear bags are just sitting on the trailing arm and bolted to the frame on the top.
