fuel setup for 2006 motor....
So, my motor looks like this one. It has one feed. I was planning on using a fuel sending unit from an 87 blazer (unit has 4 outlets), and fuel pump from 1990 iroc camaro. Do i need to order anything else?
1992 Gmc 2wd 1972 Chevy Blazer 2wd |
Re: fuel setup for 2006 motor....
You'll also need a Corvette fuel filter/regulator to use the returnless fuel rail.
Posted via Mobile Device |
does this motor have the regulator built in at the fuel rail?
Has more rust than truck...
No, If it did then you would have a feed and a return line.
is there a cheaper (yet just as good) alternative to the corvette filter/regulator?
So this is what i have so far: 1990 Jeep Wrangler gas tank (25 gallon. It is what fits, don't ask) - spectra premium #JP1D 1987 Blazer sending unit - spectra premium #FG12k 1990 camaro iroc fuel pump - ACDelco #EP241 2000 corvette filter/regulator - wix - #33737 Anything i might be missing? I plan on ordering from rockauto unless someone can recommend a cheaper place? (I will be getting this stuff shipped to the border so trying to order everything from one location)
1992 Gmc 2wd 1972 Chevy Blazer 2wd Last edited by 72gmcshorty; 06-23-2011 at 12:10 AM. |
A Wix filter is a pretty good alternative to the $100+ AC Delco, they're about $45. Any other brand I would stay away from.
![]() Join Date: Aug 2004
difference you are asking about is here.
http://www.ls1tech.com/forums/fuelin...-vs-ep381.html the LS motors need 58PSI at the rail minimum.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
#8 | |
Thanks for this. Changed my list. I wish incorrect info like this (using pump ep241) was taken off this site.
