BBC TBI Swaps Suck!
Ughhhhh. . . ... This job just plain sux.
The 90°F w/60% humidity weather isn't making it any better. Makes me want to buy some better heads + cam & not do this again. I would much rather be working on my 64 (in the shade).
Re: BBC TBI Swaps Suck!
I've done a motor swap in near freezing temps with my buddy. In extreme hot and extreme cold, it's hard to focus on the task at hand. In the hot you wear out a lot quicker, and in the cold... EVERYTHING HURTS. God forbid you smack your knuckles against anything.
If you're even thinking about better heads and cams, you better go ahead and do it now. You'll regret not doing it later. Once the 454 is installed and you're roasting radials at every red light, you'll forget how much it sucked. Keep the pictures coming ![]() ![]() |
1962 C-10
Anything would suck at 90°F w/60% humidity !!
Joseph Chavez ![]() "See the USA in a Chevrolet!!" ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1962 C10 Shortbed Fleetside 327/th350 GV overdrive 1974 C10 Longbed Fleetside 350/th350 "The Trash Truck" 1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4 2015 GMC Sierra SLE 1500 4x4 |
been here longer than Liz
Those $20-40 fold out 10x10 awnings are worth their weight in gold for projects like this. Still hot & humid, but at least you're not baking in the sun.
~Greg~ Mac's Garage '87 SWB 6/8 drop "Piso" '08 CCSB Silverado DD the departed '89 GMC K5 Jimmy 4x4 "Rusty Nuts" '77 Chevy K5 Blazer 2wd '83 Chevy stepside "You get what you pay for" - Mike 'swervin ervin' Ervin |
Actually considered one of these but w/my luck, a gust of wind would come along & smack it into on of the fenders.
I screwed mine into the driveway while I was using it.
#7 | |
Put foam pipe insulation on the legs. Drywall screws will somewhat hold the tent down if you're on asphalt. Sandbags work better on concrete (or gravel). |
67-72 parts collector,…
![]() Join Date: Nov 2002
So what's the plan?
Going small block?
#9 | |
Didn't get much positive feedback on the 408 swap so another generic 454 is going in. I'm re-thinking the top end though as much of a PITA this has been....
Previous owner stated 10-11mpgs but it was never that good for me.
How many miles did your 454 have on it? Did it need a rebuild or was it just time? What was your fuel efficiency? I've always wondered about a BBC in my Square Body.
Scot,... I know a guy that use to put on the early (late 60's-early 70's) oval port heads and intake,... and used a tbi adapter to keep the engine fuel injected.
He swore it was worth 100 hp. Some good info here: http://www.tbichips.com/454ss.htm
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 06-22-2011 at 04:55 PM. |
#12 | |
Weird thing is they recommended switching to a larger 750cfm TB & a single plane intake if I switched to the sbc (I wanted to utilize a Edel Perf-EGR intake I already have w/a TB adapter). They also recommended I not 'waste' the AFR's I thought of using (that are just sitting on a shelf gathering dust) & go w/Vortecs (different rockers, different tins, different intake, yada yada yada...). As far as the standard ovals (vs the peanut ports), you can't find anything w/a small enough chamber for the smog blocks dished pistons. Go to an earlier block & you don't have the provisions for the electronics. It makes me want to yank the TBI to swap in a spread-bore & HEI. KISS....
#13 | |
Garage wrench
-Adam 90 V1500 GMC Suburban 350/700R4/NP241..... 01 Saturn SL1 stock DD..... |
I sure wish I would have found my 'ahh-ha' item w/the pre-mature failure. Bottom end looks clean.
Lifter valley looks clean. Top of heads look clean. No obvious breaches @ the head gaskets. End pieces of the intake gaskets broke off when removing the intake so it's difficult to tell there (it doesn't look like there's been a long time issue). Lots of metallic floating around. I guess the rod and/or main bearings seized to the crank. Double row timing set & 4-bolt mains. The number on the top side pad matches the VIN number so it's in pretty good shape for the OE block. I didn't expect the pistons to look like they did so I'm researching the p/n's tonight. Rod ends were numbered so maybe it's been apart @ some point (did they stamp OE stuff?). IDK....
#15 |
Happy to be here
![]() Join Date: Mar 2000
Scot- I was at ACE Hardware yesterday and they had a pretty nice 10x10 pop up for 49.00. Add a couple of bungie cords and some free weights and your good to go. It makes it a LOT better. Throw in a hi-po fan and you are golden.
Sounds like its GM crate time to me.
#16 |
Have you checked your oil pump screen? I know when I took my pan off and looked atthe screen, I found a huge ball of silicone blocking the pickup orifice. I have some pics in my build thread.
#17 |
Watch out for your cornhole !
![]() Join Date: Jun 2003
I feel your pain Scot. I've got a 454 TBI dually myself that's using coolant and flattening the cam. I'm going small block on mine when I fix it. I figure I can buy a nice small block and all the little widgets to do the swap for less than a 454 will cost me.
#18 | |
I pulled the mains off for a quick inspection & the bearings were definitely DEAD.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 06-22-2011 at 11:15 PM. |
#19 |
yeller
I tore the top end off a 350 TBI in our old 90 Suburban...swore I would never do that again, lol!! So much BS in the way of everything!
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
#20 | ||
#21 |
![]() Join Date: Apr 2009
You have a PM
#22 | |
Slots go on anything!
When I did the engine in my '87, I was actually pleasantly suprised by the lack of stuff to make it go. I was expecting something similar to an '86. Those super suck. Seems like theamount of lines/hoses, etc was about the same swapping the TBI in place of the 2 bbl carb in the '74.
1974 Jimmy- 5.3/4L80e/NP241 |
#23 |
Scot, if you decide to go carb, I have what looks to be a real new quadrajet that came off a fresh 454 I picked up two weeks ago. I'll let it go cheap since I don't truly know the history on it.
Fawker Fab three seater rock crawler buggy 498 BBC/SM465/203/205 doubler, propane, 5.13's, 42" PB Rockers '66 C10 - The new hot rod '77 3+3 Dually - 12 valve 4wd conversion tow rig project '28 Ford 2 door sedan street rod RevLimit Offroad "Hang on beer, we can do this." |
