06-22-2011, 04:35 PM | #1 |
56 - autocross
What radiator?
What size radiator should I use for my 56? Would a griffin for a 67 to 69 camaro work? Or are there better options?
06-22-2011, 07:24 PM | #2 |
Hollister Road Co.
Re: What radiator?
Camaro is a cross flow and way to wide. Griffin makes one for your truck
06-22-2011, 07:49 PM | #3 |
Re: What radiator?
I used a camaro 67-69, bought new on egay, welded 3/8 strap on core support and tapped for fine thread worked good. I didnt like tank sticking up over core support my prefance
06-22-2011, 08:57 PM | #4 |
Re: What radiator?
I just placed a order for one from Wizard Cooling and should have it in two weeks.Bolt in direct with a trans cooler built in and a electric fan.Looks good in their ads so in two weeks I'll fine out when i unwrap it,lol.
06-23-2011, 05:42 AM | #5 |
Re: What radiator?
We offer these. made in the USA aluminum or copper and brass. if interested
06-23-2011, 01:23 PM | #6 |
Re: What radiator?
I bought one a few years back on ebay listed as a 55-59 rad but it's too wide. It still works, I had to make some adjustments to the core support but no big deal. It might be for a 58-59 if they are wider.
06-23-2011, 05:38 PM | #7 | |
Re: What radiator?
I find that I'm unexpectantly in the market for one! Long story short.....When I picked up my truck the PO included a new one he bought... boxed up never opened and definately never used, recently I opened the box and low-and-behold it's for an AD not a TF.... dohhh! Cost of shipping included would be great as well, been tramatized by the UPS driver a few times on that one. Last edited by 55metalmonkey; 06-23-2011 at 05:40 PM. |
07-13-2011, 07:48 PM | #8 |
Re: What radiator?
Well cancel the order when i called Wizard Cooling today because they never did anything with my order after three weeks.All he had to say was that he understood why i canceled my order,so now instead of bolting in a radiator i'm looking to place another order for one.Buyers beware when dealing with Wizard Cooling in NY.
07-19-2011, 02:48 PM | #9 | |
Re: What radiator?
58 Apache short fleetside ona 64 chassis: |
06-28-2011, 01:56 PM | #10 |
Re: What radiator?
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWNX%3AIT
$165 including shipping...sitting in my 53 3100 |
06-29-2011, 05:40 AM | #11 | |
Re: What radiator?
07-06-2011, 09:23 PM | #12 | |
Re: What radiator?
I don't mind the $369 for the U.S. Radiator one mgbmike lists and its local to me, but IF (and it's a big "if") I can get one for $200 less AND it works, why not? There are plenty of other uses for that $200 on my truck, unfortunately. |
07-06-2011, 11:21 PM | #13 |
BIG CHEVY 3600 LONGBOX
Re: What radiator?
I have heard it is best to change the antifreeze every 15,000 miles to protect your aluminum rad and heads.
"I recommend changing the coolant every 15,000 miles or so, even for extended drain interval coolant. As coolant ages it becomes acidic and can even hold an electrical charge. This charge can change the voltage of the engine temperature sensor giving a false reading to the engine computer. Old acidic coolant destroys the aluminum in the radiator and engine head. " efficientmileage.com
If I were given 8 hours to chop down a large tree, I would spend the first 6 hours sharpening my ax. Abraham Lincoln http://s729.photobucket.com/albums/w...cpZZ3QQtppZZ20 |
08-10-2011, 10:11 AM | #14 | |
Re: What radiator?
07-07-2011, 05:05 PM | #15 |
Re: What radiator?
Any opinions on this:
http://www.championradiators.com/page/423744122 There is also a two row. http://www.championradiators.com/page/430247590 Just noticed that the manufacturer is the same as the Egay one previously posted above.
58 Apache short fleetside ona 64 chassis: Last edited by poncho_villa; 07-07-2011 at 05:11 PM. Reason: mo info |
08-09-2011, 11:40 PM | #16 | |
Re: What radiator?
08-10-2011, 12:17 AM | #17 |
Re: What radiator?
Sounds great! The side flanges lined up and bolted up good? Any details on shipping?
08-14-2011, 12:19 AM | #18 |
Re: What radiator?
08-14-2011, 11:19 PM | #19 |
Re: What radiator?
Awesome! Thanks Bob. That's what I wanted to hear/read! I ordered two. My buddy has a '56 with a big block that has cooling issues also.
08-02-2011, 12:19 PM | #20 |
Re: What radiator?
Walker rads. been building rads for rods for 70 + years. That's where I got mine.
08-02-2011, 11:45 PM | #21 |
Re: What radiator?
Btt. So do you guys think the reconditioned original copper/brass one will be sufficient enough for an LS motor?
Long live SLIM ------------------ At least try to buy American |
08-03-2011, 12:14 AM | #22 |
Re: What radiator?
I doubt it! That is what I have now and need to upgrade. The stock rad was designed for about 5 lbs. of pressure and about 150 horsepower. Mine has failed three times with a first generation small block and I'm shopping. Great price you found tho. I'd also be tempted.
08-03-2011, 12:19 AM | #23 | |
Re: What radiator?
08-03-2011, 05:44 PM | #24 |
Re: What radiator?
I have a 54 Pro Street truck with a BB in at 632 hp. I used a U.S. Radiator model "Dessert Cooler" I use distilled water and a bottle of Justice Brothers water cooler. I only have a fan shroud no electric fan and no AC. I run 170-185 all day long. I have been told though that all these modern engines including my BB were designed to use a cross flow radiator. I can only tell you my experence. Also I use a 15lb. radiator cap. I had a 6lb cap but my temps were higher than I wanted. Hope this sheds a little more light on your inquiry. Remember one thing "buy cheap buy twice".
08-03-2011, 02:01 PM | #25 |
Re: What radiator?
Just bought this for my truck. Haven't got the truck back together yet so I don't know how well it keeps it cool, but the fit was perfect and the price was very reasonable.
Somehow, the idiots survive despite their best efforts to kill themselves. - dcozzi |
