Old 06-23-2011, 05:41 AM   #1
67C10BUB
67C10BUB's Avatar
Hooking up the AC
Anyone hooked up the AC in their 5.3 or 6.0 swap (with the low mounted factory compressor) yet? I was hoping to get some advice on getting the hoses. I have the Old Air AC system, but I didn't get the kit with the hoses, since I didn't think they would work anyway. Old Air sells a hose kit with lots of fittings to make your own, but I would have to have them pressed on. Any advise out there?
67 5.3L Build
67C10BUB is offline   Reply With Quote
Old 06-23-2011, 09:30 AM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Hooking up the AC
Parker Store, Swagelok, or similar company would be able to make you any hose you need. Just find the length you would need with an old peice of hose; then take your hose ends (or know what kind you need) with you and show them what your looking for. They can select a compatible hose type, and get you the right fittings and press together all on site. Its a pretty nice way to get custom hoses, and they don't cost a ton compared to ordering a "hose kit" that may or may not work on your application.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 06-23-2011, 09:55 AM   #3
Clyde65
Clyde65's Avatar
What he said^^^^^^
I have an Old Air system too and the LS compressor just like you. the only thing about it is when I turn on the ac or heater, my voltmeter goes down to just under 12v from about 14, I havent but plan on talking to them about it. I also used the Doc's compressor connections to move the ac connections so I could connect easier.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 06-23-2011, 11:46 AM   #4
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Clyde did your system come sealed with reefer oil, or did you have to add it manually? I may or may not have some input on your voltage drop but need to know that part first.
Old 06-23-2011, 03:26 PM   #5
Clyde65
Clyde65's Avatar
Br3W, I have no idea what your talking about, sealed? reefer oil?
Clyde65
Rebuild of Clyde
support our troops!
Old 06-23-2011, 02:51 PM   #6
67C10BUB
67C10BUB's Avatar
My local hose shop is run by an idiot. He made a few hoses for me in the past and I wasn't all that pleased with them. At this point, I just like to do as much as possible myself.
67 5.3L Build
Old 06-23-2011, 03:01 PM   #7
leddzepp
Moderator
leddzepp's Avatar
who did you go to locally? i have had good luck with the hose man in grand terrace.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 06-24-2011, 06:03 AM   #8
67C10BUB
67C10BUB's Avatar
There is a Hose Man near by. Maybe I will see what they charge if you liked their work. I went with a privately owned shop (that I can't recall the name of).
67 5.3L Build
Old 06-23-2011, 04:06 PM   #9
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Did your a/c compressor come on the pullout motor or did you buy a new one from a parts store? All refrigeration aka "reefer" (not weed, thats a different conversation) uses some sort of lubricant in the system for the compressor, because the refrigerant gas itself does not lubricate.
Some systems have a lubricant built into the refrigerant, others use an additional oil like Pag 100. Your voltage drop made me wonder if the compressor was encountering mechanical resistance, from lack of lubrication.
Old 06-23-2011, 04:50 PM   #10
Clyde65
Clyde65's Avatar
Well, I got it from a wrecked truck that I pulled it off of. it was a running truck and ac blew cold but looked like a train met it in the middle. I just had it charged and a friends AC business, this isnt something new, it has pretty much always did the volt sucking. I am going to rattle the Old Air peoples cage ( I live very close and they really love me, NOT!) so maybe they will have an answer.
The first time I went to ask them a question, they didnt want to talk to me cuz I have the LS compressor on it and not the Sanden I used to. It blows cold and works fine other than the voltage, would a relay going out cause this? just a stab in the dark.
Clyde65
Rebuild of Clyde
support our troops!
Old 06-23-2011, 10:32 PM   #11
TR65
TR65's Avatar
Hey 67,
Here is how I hooked up my low mount compressor on my LS2.
http://67-72chevytrucks.com/vboard/s...d.php?t=468107
TR
1965 C10 SWB Fleet
Two owner
LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880
TR65 is offline   Reply With Quote
Old 06-24-2011, 05:58 AM   #12
67C10BUB
67C10BUB's Avatar
Originally Posted by TR65 View Post
Hey 67,
TR
Thanks TR65, great write up. It was very helpful, but those Aeroquip fittings are a little pricy for me. I am considering the Old Air hose kit, which is $95 for everything.
67 5.3L Build
Old 06-24-2011, 11:00 AM   #13
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Clyde, I'd be inclined to think the relay isn't the problem If you hooked it up without a relay, I could see a voltage issue if the current is passing through a small switch wire or something...but it you have a relay I don't see what the issue would be.
The mechanical resistance only occurred to me, because I had a customer with a large commercial cooling unit whose compressor ran dry and seized.....
Old 06-24-2011, 12:41 PM   #14
Clyde65
Clyde65's Avatar
BR3W,
The reason I question the relay is because the way it is wired, it draws the power through the fuse block, not the battery like most relays are done.
Clyde65
Rebuild of Clyde
support our troops!
Old 06-24-2011, 03:59 PM   #15
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
^really?
I wouldn't want the a/c running through the fuse block IMO.
Disconnect the relay, start the truck, hotwire compressor to the battery on (with inline fuse!) and see if it drops.
Old 06-24-2011, 04:47 PM   #16
Clyde65
Clyde65's Avatar
Just for more information my dad's truck wit Old Air does the same thing. also it seams it is more the fan and the unit and not the compressor, he has a Sanden and I have the stock 02 LS compressor.
Clyde65
Rebuild of Clyde
support our troops!
Old 06-24-2011, 11:44 PM   #17
clinebarger
Are you using the original fuse block? If so, You need to run a "dedicated fused curcuit" to the blower motor relay. A 10 gauge wire from the battery/alternator/starter with a 25 or 30 amp fuse inline should correct your problem. I have a Painless single megafuse holder I will give you John. Those cheap autostore fuse holders SUCK!
BR3W CITY, On automotive A/C the compressor is ran by the belt/engine via the electromagnetic compressor clutch, Electrical power does not run the compressor, Just the clutch which is a "low amp curcuit". Compressor Clutch Relays are used as a control device for the PCM in late model vehicles, Not as a "high amp" switch.
clinebarger is offline   Reply With Quote
Old 06-26-2011, 02:10 AM   #18
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
good info clyde.
Old 07-02-2011, 10:53 PM   #19
67C10BUB
67C10BUB's Avatar
It looks like I am going with Hose Man. I talked to them down there and they said they would measure and fit them to my truck if I bring it down. Anyone have a good place to get my system charged in SoCal?
67 5.3L Build
Old 07-02-2011, 11:23 PM   #20
Lee H
Lee H's Avatar
Foothill radiator in Upland on Foothill Blvd a few blocks east of Euclid.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 07-03-2011, 12:14 AM   #21
67C10BUB
67C10BUB's Avatar
Thanks!! I take it you have had a good experience with them before?
67 5.3L Build
Old 07-22-2011, 12:39 PM   #22
67C10BUB
67C10BUB's Avatar
Thanks Lee H...Took it to Foothill Radiator and they were very helpful.
67 5.3L Build
