06-23-2011, 11:52 AM | #1 |
got some blazer questions
nubie to this section!!! ok guys im picking up. a bone stock never been modified. 84 blazer 4x4. looks like it has power options. now this thing has been sitting for 8 years and not been started in 5. so whatam I gonna need to look for to make sure its a good block? crank turns. I know I have to change all fluids so why else should I do before cranking the engine? anything else to look for before finalizing the sale?
Posted via Mobile Device update!!!! she's home!!!. turns out its a 305 with a 700r4. also its a silverado!! interior ceiling header panal fell down but all else is good. ill need bucket seat covers. has the center console original am/fm tape. got the back window down but wont go back up and the tailgate lock wont turn with the key. but hey for 900 I can't complain. no rust at all as its a NM truck!! ill post pics soon I wanted to ask what options were available for this year blazer?
1967custom Last edited by michael bustamante; 06-27-2011 at 02:07 AM. |
06-23-2011, 09:18 PM | #2 |
78K & 79C Jimmys
Re: got some blazer questions
well for me the body mounts,rockers,under the belts,rust across the top of the back gate
may wana confirm the block some came with 305s sitting that long.....drain the oil,gas,maybe brakes n fluid shocks may have seized rubbers gona be shot/dried up in gas lines rad hoses i duno if i'd wana start it,with out changing stuff
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
06-24-2011, 12:21 AM | #3 |
definatly need to change all the fluids and im sure shocks are shot. you guys think ill need to dunk the gas tank?
1967custom |
06-24-2011, 06:10 AM | #4 |
78K & 79C Jimmys
yup duno bout dunk if it cleans out ok
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 Last edited by motornut; 06-24-2011 at 06:11 AM. |
06-24-2011, 11:51 AM | #5 |
If it's sat that long, you need to remove the spark plugs and squirt some Marvel Mystery Oil (or some type of oil) into the cylinders before you start cranking on it. Those cylinders are dry and you don't know for sure that the oil pump even works correctly.
I'd drain all the fluids, including the gas, install a temporary cheap clear plastic in-line fuel filter just before the carb. Do it up by the carb so it catches everything possible just before it dumps in the carb, also, being up top, it's easy to see and change out. if you do get it started, let it run for 10-15 min to get up to operating temp so you'll be able to spot any leaks. Also, after it's been running a bit, check the oil and coolant to make sure you dont have one getting into the other. As long as the rats haven't done any damage, you got air, fuel, and fire.....you should be able to start it right up. I did this very same thing on a suburban that had sat for 5yrs. Posted via Mobile Device
1984 K10 SWB "Coal" 1987 K5 Blazer "Ole Miss" 1979 GMC Jimmy (Project) 2008 F250 CC 4x4 King Ranch 6" lift on 37's (Spartan-ized!!) 2008 Dodge Challenger SRT8 Hemi Orange 2008 HD StreetGlide 2007 HD Custom Fatboy 1980 Suburban (will be for sale or trade soon). |
06-24-2011, 04:17 PM | #6 |
good idea bout the marvel. o was thinking the same thing
you think I should change diff and trans oil too? Posted via Mobile Device
1967custom |
06-26-2011, 03:02 PM | #7 | |
Chevys Kick A$$
Yes you should but I wouldn't worry about it till you get it running. Would be a good idea to check those fluid levels though. Yes I would drop the tank defiantly. You can squirt oil in the spark plug holes or also if you have a spare distributor take and grind the teeth off it and put it in and prime your engine with it. You can check the oil pump out this way cause if it works it should build up pressure! Yea I would check for rust in the fenders and back by the tailgate also check the frame around the steering box for any cracks I have seen my fair share of broken frames there. Posted via Mobile Device
*HOODS is what I answer too* -'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold -'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit -'86 K5 Blazer Silverado 6.2 4" lift 35"s -'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's -'83 Monte Carlo T-Tops. 126,500 Original Miles -LATER I would rather push a Chevy then drive a ford!!
06-27-2011, 01:52 AM | #8 |
checked the frame. at the gearbox and its good but the steering wheel has about a 40 % turn until the steering catches. im thinking worn gearbox. no rust at all. no extra distributer buy that's a good idea. Man this truck has alot of emissions hose!!. oh and the trucks home now :-) changed oil. rad fluid. picked up royal purple. gear oil for the diffs. monroe heavy duty shocks. new pcv. hooked up cheapie fuel filter and hooked up like wad suggested above. new optima red top battery. new ac delco rapid fires. cap and rotor. anything I forgot?
1967custom |
