Old 06-23-2011, 01:08 PM   #1
imdarren
imdarren's Avatar
HEI VS Pertronix
Lots of HEI questions coming up. I have installed 2 Pertronix setups in my trucks, and have loved them. Keeps the original look, with newer technology and performance.
The question:
Has anyone done a comparison to see if HEI has any advantage over the Pertronix setup? I personally love that the size stays small, and looks original.
Darren
Washington State
1967 Chevy C10 LWB Rodstoration In Progress.
1972 K20 Cheyenne Super
imdarren is offline   Reply With Quote
Old 06-23-2011, 01:34 PM   #2
DANTIP
DANTIP's Avatar
Re: HEI VS Pertronix
I liked the Pertronix in my SWB 4x4 because the factory dizzy is smaller in diameter than the HEI and the engine sits very close to the firewall. Also keeps the factory look! I think there are other competitive systems that don't require any wiring changes like the Pertronix does.
DANTIP is offline   Reply With Quote
Old 06-23-2011, 01:52 PM   #3
D.PASSMORE
One of the First
D.PASSMORE's Avatar
As DANTIP said. I purchased a Pertronix FlameThrower II billet distributer and coil. Had the distributure recurved to a stock GM application. Use summit wires and AC/DELCO plugs. Runs good, but notice that it burns hotter in the cylinder.
Don't forget to take out/replace the ign resistor wire or run another 12 V source wire to the coil. It likes solid 12VDC.
DAVID PASSMORE
ST AUGUSTINE ,FL
ZIP 32084
'71 SWB K/10 CUSTOM DELUXE (Chili)
'72 BLAZER K/5 Muscle Truck (Mule)
'72 LWB K/20 CHEYENNE (Blackie)
D.PASSMORE is offline   Reply With Quote
Old 06-23-2011, 02:42 PM   #4
imdarren
imdarren's Avatar
Good point about the wire.
I did not change my wire. Seems I checked the voltage, and it was 12v.
My truck is a 72 K20. Did all the trucks have a resistor wire?
I'm thinking I better go back and re-check that. Sure runs good though.
Darren
Washington State
Old 06-23-2011, 02:55 PM   #5
Lee H
Lee H's Avatar
Seems like the pertronix works very well for daily driver applications, good starting, improved drivability around town and and on the freeway, improved mileage. However I have experienced that they tend to miss above 6K, allot.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 06-23-2011, 03:17 PM   #6
eurospec1
eurospec1's Avatar
Agreed, for all around performance, ease of install, reliability, you absolutely cannot beat an HEI
68 SWB Fleet 383
eurospec1 is offline   Reply With Quote
Old 06-23-2011, 03:39 PM   #7
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Used/junkyard HEI's are not expensive. But, they may come with a problem or two. My '69 had an HEI when I bought it. It was okay for a few years...okay 2 years...and then I began to have trouble. I'd let off on the gas and it would die. I could throw the gear selector into neutral and it would fire back up, then I'd drop it in gear and keep driving. I had already replaced the ignition module and I'd also put a different vacuum advance on it. The cap, rotor and wires as well as plugs were all good. I had already put the Edelbrock Q-jet on it, as well as a new fuel filter. So, I was just biding time....until one New Year's Day. It died at a traffic light and wouldn't restart. I had it hauled home and decided that it was time for another distributor. I shopped around for a short time and decided that an Accel HEI (actually a reman unit by Accel) was what I wanted. After it was installed, no more problems.
The HEI that came out is still in the box that the Accel came it. I found that the wire to the reluctor had a break in it. When you let off of the gas, the vacuum advance would move the breaker plate and temporarily break the connection and that's why it would die. It can be fixed, so I'm hanging onto it.
Thought I'd share this in case anyone else has ever had a question.
Member Nr. 2770
Old 06-23-2011, 04:37 PM   #8
Wrenchbender Ret
I like the factory HEI unit. It has a spark like a bolt of lightening. They are dependable. For my Task Force trucks I use the petronics changover kit because of the firewall clearance. Some petronics systems still use the resister. Read the directions.
Wrenchbender Ret is offline   Reply With Quote
Old 06-23-2011, 06:42 PM   #9
FLDBRED
I think one of the big advantages of the HEI is not only the elimination of the points which the Pertronix also does but the large amount of volts it delivers.I guess you could up grade your coil with the Pertronix.
FLDBRED is offline   Reply With Quote
Old 06-23-2011, 07:11 PM   #10
406 Q-ship
406 Q-ship's Avatar
I have used the Crane XR1 (simular to the Pentronix) and HEI's. Here is my opinion, the HEI is a cheaper change if you can find used ones in the "pick and pull" than one of the kits. The better side to a points conversion kit is that the advance is stays the same. Hei's came out of the emission era and have a very broad advance range that it is more difficult to use on a performance engine. A performance engine will require more intitial timing, with a HEI it will end up with too much total advance unless you can find someone who knows the proper way to set them up. On a stock engine the HEI is the cheapest and best way to go, you have a bit of cam and need 12° of initial timing then a Crane XR1 or the Pentronix is the way to go.
Lifes journey is not to arrive at the gate well preserved, it is to slide in sideways all used up and wore out yelling.....God what'a ride!
Where patience fails, force prevails
Stapp's Ironical Paradox "The universal aptitude for ineptitude makes any human accomplishment an incredible miracle."
406 Q-ship is offline   Reply With Quote
Old 06-23-2011, 09:09 PM   #11
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
The only downside to an HEI is if you're doing any kind of high RPM stuff... they start dropping serious voltage after 4,500 RPM's. For most cats this ain't a problem since their engines never see that many R's at all. Some never.
But for me, where my engine will see 6,000+ RPM's quite a bit... some kind of Aftermarket HEI was in order. I use an MSD Pro Billet unit. Anyways... Just a thought in case anybody is puttin' an HEI in a racing, or street/strip rig.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 06-23-2011, 10:28 PM   #12
70cst
70cst's Avatar
I have used Pertronix in my truck for years w/o any issues....yet
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 06-23-2011, 10:40 PM   #13
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
huge positive on the HEI... You can get parts for it at any parts house in the US. on any day of the week.
Pertronix , unless you have a performance shop in town, you'll have to order the stuff and wait till it gets shipped.
Old 06-23-2011, 10:51 PM   #14
70cst
70cst's Avatar
Good point
