Old 06-24-2011, 01:34 AM   #1
Rods57
Rods57's Avatar
Rods 57
Ok so i have been hanging out here a while but have not posted my build yet. So here it is. I started with 3 trucks a 55 GMC big window, a 57 Chevy and a 59 Chevy. total cost 1700, drove one home. the first pic is the left over parts truck that i sold for $600.
i used the 55 cab, the 59 dash, it was perfect and i had no GMC parts and the frame and bed from the 57. I got a 78 camero for $50 and used the front clip, rear end, brake pedal cluster and trans. Shes a real looker huh...my wife would not even let it off the trailer, not kidding.
A local guy here in Idaho has a jig to do the front clip he has done like 40 of them so no credit to me for that part. I got a killer deal to get sandblasting done and was able to get the frame, cab and a ton of pieces done.
Rods57 is offline   Reply With Quote
Old 06-24-2011, 01:44 AM   #2
Rods57
Rods57's Avatar
Re: Rods 57
Then i got a motor from a friend that had the block numbers damaged so its a 75 blaser or corvette, I am sticking with the vette story cause it sounds cooler.
Any way its a 4 bolt 350, heads with 202 valves and roller rockers, mild cam. turbo 350 from the camero, rebuilt trans twice but that's a long story and it was costly, and my fault. one and only time i have ever broken a case while bolting it in.
I made a rat rod engine stand that holds the engine and trans out of scrap in two hours, cause i wanted to..
posi in the 10 bolt that i picked up for $100
longer rear shackles, removed some springs.
all new front end components.
Old 06-24-2011, 01:53 AM   #3
Rods57
Rods57's Avatar
Re: Rods 57
Aluminum fuel tank in the rear.
Wide whites on all fours and red steel wheels.
Name:  May 07 006.jpg
Name:  May 07 007.jpg
Weld and grind time now. Meet Kabwe on-line and started cutting up the body shortly after that. thanks man.
Old 06-24-2011, 01:57 AM   #4
Rods57
Rods57's Avatar
Re: Rods 57
More cut and weld, cab was dropped on its back at some point so I needed to do a lot of welding and cutting.
Old 06-24-2011, 02:52 AM   #5
Kabwe
Certified Car Nut
Kabwe's Avatar
Re: Rods 57
Great job man, everything is looking really good. I'm glad you started a build thread. Keep the pics coming.
Kabwe is offline   Reply With Quote
Old 06-24-2011, 05:44 AM   #6
kgmunro
Re: Rods 57
wow nice looking frame...what are your plans for a color on the truck with the red frame? Same color or a contrasting color?
kgmunro is offline   Reply With Quote
Old 06-24-2011, 09:18 AM   #7
Rods57
Rods57's Avatar
Re: Rods 57
Thanks, O am planning on the paint being black, flat or shine is still up in the air.
Old 06-24-2011, 10:28 AM   #8
1956chevtruck
1956chevtruck's Avatar
Re: Rods 57
Love the frame! If I were to do mine over, the frame would be bight red. Welcome to the site, keep us posted. Looks like you're doing an awesome job!
Byron
1956chevtruck is offline   Reply With Quote
Old 06-24-2011, 11:07 AM   #9
Rods57
Rods57's Avatar
Re: Rods 57
Thanks for the comments, not a professional so I was a bit nervous putting up pictures of my work.
Old 06-24-2011, 03:41 PM   #10
Kim57
Kim57's Avatar
Re: Rods 57
Very nice looking frame.
Nice job on the cab repairs also.
Kim
Kim57 is offline   Reply With Quote
Old 06-24-2011, 05:32 PM   #11
hammerdog57
hammerdog57's Avatar
Re: Rods 57
Very nice build. My camaro clip install is close to yours. How much clearance do you have from distributor to firewall? I see you used the stock motor mounts, which i plan on using if i can. Keep the pics coming.
hammerdog57 is offline   Reply With Quote
Old 06-24-2011, 11:46 PM   #12
Rods57
Rods57's Avatar
Re: Rods 57
I have like 1 1/2 inches at the firewall.
Old 06-26-2011, 12:26 PM   #13
Rods57
Rods57's Avatar
Re: Rods 57
Here is a close up of the motor mounts you can still see one of the original holes.
Old 06-26-2011, 05:41 PM   #14
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Re: Rods 57
Sweet looking build! The clip install looks very similiar to the way mine was done. Keep the updates coming!!
ChuckDriver is offline   Reply With Quote
Old 06-26-2011, 07:58 PM   #15
hammerdog57
Re: Rods 57
Attachment 766172
Thanks for pic.
Old 06-26-2011, 10:30 PM   #16
kgmunro
Re: Rods 57
I'd swear in the one pic with you sitting in the cab I can hear you making engine noises!
Old 06-24-2011, 07:32 PM   #17
Wheelie
Re: Rods 57
Very nice clip integration there. Very smooth. Got closer pics of the frame where the clio meet?
Wheelie is offline   Reply With Quote
Old 06-24-2011, 09:05 PM   #18
Rods57
Rods57's Avatar
Re: Rods 57
here are the closer pics, i will try to blow them up if i can.
Old 06-24-2011, 09:42 PM   #19
Tri5Nerd
Tripple Five Fanatic
Tri5Nerd's Avatar
Re: Rods 57
Good job, I think when you do something to the truck for the first time you get kinda nervous but once you get into it and it starts to turn out how you want it you get more confidence, this is what I say now, if I mess it up I can always do it over.
Love the red frame paint, is it single stage of BC/CC?
Tri5
1955 Chevy Stepside/LS1 drive train
http://67-72chevytrucks.com/vboard/s...d.php?t=371513
Tri5Nerd is offline   Reply With Quote
Old 06-24-2011, 11:39 PM   #20
Rods57
Rods57's Avatar
Re: Rods 57
Thanks a lot. I really like it now that i did it. Its actually red baron red powder coat. I agree with you, its kind a hard at first then you cut something, fit it back together and it looks better and you gain confidence.
Old 06-24-2011, 11:45 PM   #21
Rods57
Rods57's Avatar
Re: Rods 57
Here are some more of the cab, the steps needed to go and i had to re-build the drip rails it had 69 holes in the firewall, yes 69 I don't know why. fuel door filled in.
Name:  DSC_0310 turned.jpg
Old 06-25-2011, 12:44 AM   #22
bubba327
HOW long until spring??
bubba327's Avatar
Re: Rods 57
Hey another local guy!! welcome to the fun!!
That is about the sharpest looking frame I have seen. Truck is really looking good.
69 chevelle convertible
71-C-10 short-wide and low
64 C-10 custom shortbox "Bubba"s Recycling project"
bubba327 is offline   Reply With Quote
Old 06-25-2011, 01:09 AM   #23
Rods57
Rods57's Avatar
Re: Rods 57
Thanks, nice to see more guy locally out here too.
Old 06-25-2011, 01:29 AM   #24
OrrieG
OrrieG's Avatar
Re: Rods 57
Yeah, I just noticed you are from Boise too. Some of us are trying to get together at Motorfest, there is a thread in the regional section.
Old 06-25-2011, 01:31 AM   #25
Rods57
Rods57's Avatar
Re: Rods 57
I just saw that, my daughter is getting married the Saturday of moterfest, but i am still going.
