Old 06-24-2011, 01:46 AM   #1
greasemonkey71
motor build
im goin to be doin an entire power train swap from an 03 gmc sierra
5.3/4l60e
into a 71 c10 lwb
i was wondering what all upgrades anyone has done to one of these motors
aside from an intake exhaust and a tune
cam? heads? headers? ignition? ecm flash?
this truck will be a weekend cruiser that im taking my time to build
greasemonkey71 is offline   Reply With Quote
Old 06-24-2011, 10:00 AM   #2
Clyde65
Clyde65's Avatar
Re: motor build
Yes all of them have been done and are being done.
If your just wanting a mild driver, then the 5.3 with a performance tune and headers will provide you with around 350HP.
with a cam and the above, your looking around 400hp or so.
The stock heads should work fine, they are aluminum and flow fairly well, there are more better gooder heads out there though, I think the 317's are on the LQ9 and they are sought after. not sure if they would work on your 5.3 or not though.
The 4l60e will need to be built to handle the hp and torque I believe.
Ignition should be OK as is, unless your are planning to use a carb.
I have a 4.8/4l60e and I estimate the HP at around 300hp without a cam, just tune, headers and Cold Air kit.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 06-24-2011, 10:57 AM   #3
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: motor build
Anything you can name, has been done to these motors.
Heads, cams, intakes, TB, and exhaust stuff are all pretty standard fair around here.
There are a few guys going bigger; prochargers, turbo, nitrous etc.
If you want to see what these engines can do, check out LS1 tech. They have every combo you could imagine at some point or another.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 06-24-2011, 01:23 PM   #4
greasemonkey71
Re: motor build
ok thanks
the motor makes pretty good power right now
but as we all know you cant get enough
Old 06-24-2011, 01:58 PM   #5
softballnrd27
Always a work in progress
softballnrd27's Avatar
Re: motor build
Heads, cam and intake would really wake it up. Ported 243/799s or some small port AFRs or Trickfolws(205cc intake port) would work. There is always the option of a stroker kit.
USMC Retired
Never trust a man who can't laugh at his own fart!
2010 Silverado Crew Cab
73 SWB 5.3/4l80e
Build Thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=695168
softballnrd27 is offline   Reply With Quote
