Old 06-26-2011, 09:27 PM   #1
jondancer
How hard to remove the bed?
How do you remove the bed of the truck? I'd like to get to the frame with the box removed and also por-15 the underside of the box.
jondancer is offline   Reply With Quote
Old 06-26-2011, 09:31 PM   #2
bosco200
bosco200's Avatar
Re: How hard to remove the bed?
Theres a plug in back by the bumper through a hole on the frame on the driver side....unplug that......take out your bolts on the bed and lift it off.
bosco200 is offline   Reply With Quote
Old 06-26-2011, 09:56 PM   #3
jondancer
A wire plug you mean? A lot of bolts?
Old 06-26-2011, 09:59 PM   #4
Hubscrub
Cruzin
Hubscrub's Avatar
yes, where you rear light harness plugs into and about 8 bolts holding it to the frame not hard at all.
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline   Reply With Quote
Old 06-26-2011, 09:59 PM   #5
71swb4x4
71swb4x4's Avatar
Four bolts. The plug he is referring to is for the taillights. There should be a grounding strap as well, maybe a couple. Two guys can do it, four is much better. Taking the tires off and lowering the rearend as low as the jack will go makes it a bit easier too.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 06-26-2011, 10:29 PM   #6
jondancer
Awesome picture thanks everyone
Old 06-27-2011, 12:44 AM   #7
eagleuh1
eagleuh1's Avatar
I use 2 2x4s nailed together and cut to just fit under the lip at about center of bed. Put 2 Eye bolts, one at each end and attach a chain, use an engine hoist and you can lift it off the frame and drive truck out from under it. Just make sure you got it balanced before lifting too high. Good luck. Jim. Set it on 4 jack stands to get it off the ground.
eagleuh1 is offline   Reply With Quote
Old 06-27-2011, 06:17 AM   #8
cdowns
cdowns's Avatar
easy to do as listed above // one man and an engine crane and aan ability to balance something is easier than trying to coordinate 4 drunk guys with 7left feet
somewhat easier to do with tailgate removed
Old 06-27-2011, 12:30 PM   #9
eagleuh1
eagleuh1's Avatar
Yeh, with my engine hoist I had to remove bumper and tailgate, it wouldn't reach fully extended to a balance point without doing that. Also, this way by yourself isn't as much fun as with 4 drunk guys with seven left feet, but there will be fewer dents and dings.
