06-28-2011, 08:45 PM | #1 |
55-57 a/c
guys,
do any of you have pics or info on your a/c setup for your 55-57 ? im looking at a vintage air kit, complete. in the coming months and doing a little home work. just curious on your install, easy or hard ? pics would be great. thanks much. leonard
http://s251.photobucket.com/albums/g...G/1957%203100/ |
07-03-2011, 09:35 AM | #2 |
Re: 55-57 a/c
I went with Vintage Air but, did not get the direct bolt in kit as I wanted the electronic controls. Even with it not being a direct fit, installation wasn't that bad. I did have to get some fittings (2X 180 degree) that didn't come with the kit but, they weren't that expensive. The bonus of what I did is electronic controls and the unit is a bit smaller. Only used this a couple of times but, it worked great.
Pictures are on my build thread.
Brandon 63 Biscayne https://www.pro-touring.com/threads/90718-63-Biscayne 57 Chevy Truck (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=321380 72 K20 Long bed stepside (wife's) 72 K20 Long bed 396 (flip or keep...?) The latest build: http://67-72chevytrucks.com/vboard/s...76#post8438476 |
07-03-2011, 09:48 AM | #3 | |
Re: 55-57 a/c
thanks for the info brandon. you got a great looking truck man. curious, what year is your engine ? i want to swap my alternator to the drivers side like yours, so i can run the compressor on the passengers side so the lines wont have to go across my engine. is yours a long or short water pump ? thanks again.
07-03-2011, 02:08 PM | #4 |
Re: 55-57 a/c
Thanks, spent about two years rebuilding it.
Engine is a 60s(?) 327. Don't know much about it but, it is a pretty fresh rebuild, there was no carbon on top of the pistons. It was set up like that when I bought the truck. I have a short water pump. Getting ready to get an alternator and PS mount made by the same company that made the AC bracket.
07-03-2011, 06:23 PM | #5 | |
Re: 55-57 a/c
take care
07-11-2011, 05:08 PM | #6 |
Re: 55-57 a/c
Vintage Air in mine. Manual controls, not a bad install. Works great!
07-12-2011, 02:51 AM | #7 |
Re: 55-57 a/c
check this guys stuff. I've used a lot of it, it fits and works like it's supposed to. practically a miracle in this day and age cheap china junk knock-offs.
http://www.alangrovecomponents.com/index.htm |
07-12-2011, 04:12 AM | #8 |
Re: 55-57 a/c
thanks for the info guys.. it's is a big help... soon i will be ordering all the components.
leonard
07-12-2011, 08:47 AM | #9 |
Re: 55-57 a/c
Leonard, This is my first A/C installation. Mike Brown (owner) at Rainbow Products in Charlotte was a big help, as was the tech at Vintage Air. (Danny at Danny's Rod Shop was a problem for me -- price and otherwise -- so much so that I did not buy local.) I'm installing the Vintage Air Gen II Compac evaporator - not the custom one, for reasons similar to yours. However, I called them and got the p/n for the condenser and small lines thru the core support that they put in the custom kit. The brackets are perfect, and this will save you a lot of time on fitment. They also have a "Tite Fit" line kit (no picture) at the compressor that points the lines downward for a clean look (but expensive at around $40).
Pic #1: I decided to run the hoses thru the wheelwell. I used the diamond-shaped bulkhead from Billet Specialties, and it really fits well in the contour of the stock inner fender, below the compressor. Pic #2: I bought the grommets from Grainger. They're perfect for the AN-6 and AN-10 hoses, (and my NAPA heater hose) but are only are available in quantities of 25 or so. This was a little expensive, but I have a ton of them and have been able to sell a few for a buck apiece to offset my cost. Pic #3: Here are the hoses under the dash. You have to wrestle with them a little bit, but it wasn't too bad. I mounted the evaporator about as high and to the right as I could. I welded studs onto the firewall to hold it because I wanted a clean engine compartment. I was going to smooth the dash, but the glove box really improves access (and I'm getting too old to crawl around under the dash!) Pic #4: This picture is a little redundant, but it shows my drier location. Once again, I used studs for mounting. I also went with the trinary switch on the drier. Hot tip: You can fit a NAPA heater hose into an AN-10 beadlock fitting by using a piece of 3/8 fuel hose as a spacer! Hope this helps. Last edited by DransportGarage; 07-12-2011 at 08:53 AM. |
07-12-2011, 12:43 PM | #10 |
Re: 55-57 a/c
I am putting in a VA sure fit for the 55-59. I ran the water lines similar to the post above but decided to run the AC lines per the VA installation (come out under the battery tray) so I would not need to recharge the AC if I ever had to pull the front clip. My build thread has some photos of the trial fit and the water line bulkhead install.
07-12-2011, 06:47 PM | #11 |
Re: 55-57 a/c
DransportGarage, thanks a ton for your detailed post. i will be bale to come back to this when i am installing mine. i need to get on the phone with VA and ask some questions.
curious, does your unit have cable or electronic switches ? im leaning toward the electric switches. also, do you have any pics of the dash where the vents are located ? OrrieG, i will step through your build thread in a bit..... 21 pages.... gotta be some good stuff in there for sure. oh yea, are the both of you running standard cooling fan or electric ? thanks for your time guys, i really appreciate it a bunch. leonard
07-18-2011, 07:57 AM | #12 |
Re: 55-57 a/c
I believe my radiator was from US radiator. I purchased it on Ebay and got free shipping. I'm only running an engine fan but, didn't have any overheating problems. Still need to change to a smaller fan and fan shroud.
07-18-2011, 06:35 PM | #13 | |
Re: 55-57 a/c
leonard
06-26-2012, 09:50 PM | #14 |
Re: 55-57 a/c
Looking at a va surefit for my 57, complete kit. Can I have it knocked out in weekend? Me and a buddy who actually knows damn near everything about mods and remodels.
Posted via Mobile Device |
