Old 06-28-2011, 10:04 PM   #1
texastrendz
Calling Suspension Guru's
I need (in plain English) how shock angles effect the rear suspension. I am running a trailing arm setup with bags in front of the axle. I need to lay the shock over some because of the length. I was wondering what the best operating angle will be of the shock. I measured about 60 degrees off of 90. Is this to much angle for a kyb series shock? Any and all help would be great.
texastrendz is offline   Reply With Quote
Old 06-29-2011, 10:07 AM   #2
Clyde65
Clyde65's Avatar
Re: Calling Suspension Guru's
shock re-locators!
ECE/CPP/POL all have front and rear Re-locators for our trucks that will make the shocks sit right when lowered.
How low is your truck? springs or bags?
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 06-29-2011, 11:33 AM   #3
texastrendz
Originally Posted by Clyde65 View Post
shock re-locators!
Sorry it is not a stock application. I really just wanted to know at what angle do the shocks start loosing function. From what I have read as long as I stay ahead of 45 degrees I should be fine. I just wanted to make sure before i start cutting up my poeder coated frame. Any and all help is appreciated.
Old 06-29-2011, 12:31 PM   #4
Clyde65
Clyde65's Avatar
I have read, the close to 90 the better but since I am not an expert, I will bow out and wait for an expert.
Clyde65
Rebuild of Clyde
support our troops!
Old 06-29-2011, 12:39 PM   #5
texastrendz
No reason to bow out, i like hearing any and all opinions.
Old 06-29-2011, 12:40 PM   #6
texastrendz
I did find a pretty cool website:
http://www.4x4review.com/Features/Te...7/Default.aspx
Old 06-29-2011, 04:52 PM   #7
SCOTI
SCOTI's Avatar
I remember reading somewhere to limit the angle to 35deg from 90/plumb. Not sure how 'quickly' from there the leverage diminishes though. Hopefully, someone will chime in w/some text to correctly educate us....
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 06-29-2011, 05:16 PM   #8
PBFAB.COM
PBFAB.COM's Avatar
There's a lot of variables that go into this, and a lengthy explaination...but as a rule of thumb try and keep the shocks between 20 and 30 degrees and you will be fine.
Nate
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 06-29-2011, 05:26 PM   #9
craig@ridetech.com
Formerly LSC71
The link above does give a lot of great information, but to dumb it down the best I can.
Mounting the shocks vertical and as far out to the wheels is the most ideal set up. Most of the time you see them angled in, this allows you to use a shorter travel shock but still have plenty of or more axle movement. Here at Ridetech we don't like to go more than 30 degrees over. As soon as you start to lay them over at an angle the effectiveness diminishes, the farther over, the more it diminishes. The adjustable shocks have an obvious advantage here over a fixed valve shock, but it all comes down to each application and what will work best for your situation and driving style.
craig@ridetech.com is offline   Reply With Quote
