Old 06-29-2011, 10:17 AM   #1
72duraburb
72 suburban with a duramax (the build)
Here is some pics of this thing in progress.
Dates aren't shown on pictures, but are as follows:
12-29-2010, 1-6-2011, 1-8-2011, 1-8-2011, 1-9-2011
72duraburb is offline   Reply With Quote
Old 06-29-2011, 10:24 AM   #2
72duraburb
Re: 72 suburban with a duramax (the build)
More pics. Dates as follows:
1-9-2011, 1-10-2011, 1-10-2011, 1-31-2011
Old 06-29-2011, 10:26 AM   #3
72duraburb
Dates:
2-1-2011, 2-1-2011
More pictures to follow. Need to sort through the memory card on camera.
Old 06-29-2011, 10:42 AM   #4
72duraburb
Here are pictures and dates when I could actually drive it around the shop on it's own power.
2-16-2011, 2-16-2011, 2-20-2011, 2-20-2011, 2-20-2011
Old 06-29-2011, 10:52 AM   #5
72duraburb
Rest of these all taken on 2-20-2011
Old 06-29-2011, 11:02 AM   #6
72duraburb
Taken 2-20-2011
Old 06-29-2011, 07:22 PM   #7
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Very nice! Did you use a stock harness from a truck or a standalone ecu?
Ryan
1969 Chevy milk truck
Old 06-29-2011, 07:27 PM   #8
sleepertruck72
sleepertruck72's Avatar
Wow, that is awesome It looks like a nice tight squeeze in there, but it looks good It must drive and sound awesome !
72 C20 Longbed
05 1500 Z71
sleepertruck72 is offline   Reply With Quote
Old 07-06-2011, 02:22 PM   #9
Dieselwrencher
It was nice seeing your Suburban in person! You did a great job on the install and in record time for a build for sure. And, thanks again for the sweet deal on the clutch TH400. It'll be put to good use.
Ryan
Old 07-06-2011, 10:08 PM   #10
jbclassix
Junk Yartist
jbclassix's Avatar
firewall mods?
-Jeremy
YOU ONLY FAIL IF YOU STOP TRYING
70 Crew Cab Build Link
70 GMC Suburban 4X4 build thread
95 Yukon Daily Driver
Rebuilding an NP205
jbclassix is offline   Reply With Quote
Old 07-07-2011, 12:09 AM   #11
72duraburb
no firewall mods but the challenge was the trans tunnel because of the size of the allison started with a 4x4 tunnel then raised it about 4 more inches
Old 07-07-2011, 06:56 AM   #12
jbclassix
Junk Yartist
jbclassix's Avatar
I saw some pictures of the white short bed pick-up at SEMA with a D-max and that tranny tunnel was tall too!
-Jeremy
Rebuilding an NP205
Old 07-13-2011, 11:22 PM   #13
72duraburb
well the trans is on the bench gettin the rebuild it didnt need but tryin to make it bullet proof I quess.
Old 07-14-2011, 12:21 AM   #14
jbclassix
Junk Yartist
jbclassix's Avatar
Is that your trans cooler behind your transmission? That's slick!
-Jeremy
Rebuilding an NP205
Old 03-01-2024, 12:35 PM   #15
Dan Castilleja
Junior Member
What motor mounts.
Dan Castilleja is offline   Reply With Quote
Old 07-14-2011, 12:49 AM   #16
Maxxd07
Maxxd07's Avatar
Gonna need to see some video....Please?????
Couple 80s
Couple 70s
One 68
Maxxd07 is offline   Reply With Quote
Old 07-14-2011, 08:00 AM   #17
72duraburb
thats the trans cooler it is a tube and fin derale 16 pass and is the only trans cooler I have on the trans. With that being said it is coming off and i am going to a plate and fin type cooler from the same company because of heating issues. They asured me that it would do the job i quess i should have done my homework first before purchasing the one i did.
Old 07-14-2011, 01:23 PM   #18
jbclassix
Junk Yartist
jbclassix's Avatar
If you are having heat issues I would definitely do something different! If the other cooler doesn't work, what about a hydraulic oil cooler? They will be more pricey, but with limited forced air-flow the "bigger-is-better" approach may be the way to go. A hydraulic oil cooler will also be tougher built. Maybe a spoiler between the frame and the rocker to force some air over the frame if that is the way your fan pulls. Are you using a trans temp gauge? Now I really wish I was going to the diesel drags!
Edit: Sorry, I forgot to add this link. Have you seen the PPE truck?
-Jeremy
Rebuilding an NP205
Old 07-14-2011, 01:44 PM   #19
VA72C10
VA72C10
VA72C10's Avatar
Nice project!!!
Old 07-14-2011, 08:24 PM   #20
72duraburb
the trans temp runs about 150-170 on my 2010 truck and I have seen trans temp as high as 220 in the burb in know these are not good numbers for any oil. Temp breaks down oil the fastest. Derale told me I just used the wrong cooler for the job so I am going with the pro opinion on this on I quess. Also thought about the shroud to pull fresh air in but not good for the gravel road I live on when it rain and turns to mud. I talked to them about the air shroud and they said it would not be needed. I will let you know the results.
Old 07-14-2011, 08:55 PM   #21
jbclassix
Junk Yartist
jbclassix's Avatar
Since I"m bugging you about coolers, what can you tell me about that radiator/fan combo? How does that hold up to the heat?
-Jeremy
Rebuilding an NP205
Old 07-14-2011, 11:24 PM   #22
72duraburb
The radiator is a griffen 31 inch wide with 2 13 inch fans offset. I have never seen the engine temp above 195 unless you are running the air and sitting in traffic then it will just keep creeping up the highest recorded temp i think is 230. If i am stuck jn traffic I wiil just turn off the air and roll down the windows. On the power tour we saw some pretty high outside temps along the way so all in all I am happy with the engine cooling.
Old 07-15-2011, 08:03 AM   #23
lolife99
67-72 parts collector,…
lolife99's Avatar
Very cool burb!
I saw it at the Des Moines Goodguys event.
Keith
Convert to disc brakes.
Old 07-15-2011, 11:06 PM   #24
72duraburb
when will our projects ever be complete?
Old 07-18-2011, 02:05 AM   #25
Dieselwrencher
Yeah, I'd like to figure that out some time too.
Ryan
