06-30-2011, 02:35 PM | #1 |
What is the best rad flush for '05 Chevy?
I know the PO did not do it and I use the truck like a rented mule.. A radiator flush seems to be in order.. What is the best stuff out there?
05 2500HD 6.0 excab 69 LWB-Gone but not forgotten! 68 Dodge Charger 383/727 69 Dodge Charger-440/4spd |
07-02-2011, 08:11 PM | #2 |
He's got mean nasty FANGS!
Re: What is the best rad flush for '05 Chevy?
Drain and refill is all that is really needed. Unless there is a bunch of gunk in it then I've used the Prestone stuff in the yellow can to flush the dexcool "mud" out of them before.
2004 K2500 Burb 1999 C3500 1985 Cutlass Supreme 1969 C-10 1967 C-10 Panel josh@67-72chevytrucks.com |
07-02-2011, 09:42 PM | #3 |
~Rest In Peace~
just replace it
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
07-02-2011, 11:07 PM | #4 |
Just a tip....Use distilled water when mixing your coolant, Using ANY other water will contaminate the cooling system with chlorine, fluoride, Iron, & a host of other chemicals & minerals.
Ive run several cars/trucks on 50/50 Dexcool/distilled water for a full 150K with no problems. |
07-06-2011, 02:08 PM | #5 | |
1968 LWB C20 / AC / Wood Bed |
07-06-2011, 08:59 PM | #6 |
Tap water can be corrosive to internal engine components, and can cause a more rapid depletion of the anti-corrosion additives found in antifreeze formulations. Well water (even with a filter) Is more risky than city water. If you have "hard water" DO NOT use it...."soft water" is better....Deionized/Distilled water is best.
07-08-2011, 05:05 PM | #7 | |
