Old 07-01-2011, 12:09 AM   #1
wicky
wicky's Avatar
bagging a c-10
Hey guys im leaning more to putting bags on my.69 than just lowering it with coils. I don't want it to lay on the rockers. So i have some questions. Is notching the frame absolutely necessary or leave it stock. Putting a small notc doesn't concern me all that much really just curious. Next is how low can i go before i need to start changing spindles and front end parts.
thanks Nick p
wicky is offline   Reply With Quote
Old 07-01-2011, 12:15 AM   #2
SCOTI
SCOTI's Avatar
Re: bagging a c-10
thanks Nick p
Apparently your not spending much time on this board checking out what everyone else is doing. You want to 'lay rocker' yet ask if notching the frame is absolutely necessary??
Heck yes, a notch will be required to 'lay rocker'. If you consider doing this task w/o droppped spindles is beyond reasonable.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 07-01-2011, 12:22 AM   #3
wicky
wicky's Avatar
Re: bagging a c-10
Looks like someone needs to learn to read i said i dnt want to lay on the rocker. I want to air up to just couple inches under stock ride height and maybe get within 2" of the ground when deflated
Old 07-01-2011, 12:30 AM   #4
wicky
wicky's Avatar
Re: bagging a c-10
And prob not even two inches for that matter
Old 07-01-2011, 11:02 AM   #5
JNJchev77
Registered Cruiser
JNJchev77's Avatar
Re: bagging a c-10
I would definitely go with a c-notch in the rear if you want to bag. The front can be done with plates on the lower CA's and a plate over the crossmember spring pocket and bags, but for it to "look right" when parked or aired out, you would want to use a 2.5" or 3" drop spindle IMO. Your ride height and quality would improve due to the lowered stance. Check with Nate at Porterbuilt, explain to him what you want and he will have exactly what you need! www.dropmember.com.
77' Chevy SB
Dropmembered Front and Rear
5.3/4l60e combo
JNJchev77 is offline   Reply With Quote
Old 07-01-2011, 11:10 AM   #6
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: bagging a c-10
Ironically when I read your original post I overlooked the don't part of "I don't want it to lay on the rockers", and thought the same thing Scoti did.
So, back to your original question. No, you don't have to notch the frame, but I would. Once you start lowering it becomes addicting. If you don't notch it now, your probably going to wish you did later. I would do it once, and do it with the best components your budget allows.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 07-01-2011, 12:44 PM   #7
SCOTI
SCOTI's Avatar
Re: bagging a c-10
Yep. My mistake.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 07-01-2011, 04:31 PM   #8
wicky
wicky's Avatar
Re: bagging a c-10
LOL yeah i think u might be right. The more i look at different trucks the more i like em slammed. I like your stance maybe even alittle lower. Do you have any pics of your truck air up and laid out. Also how close is your pumpkin to your bed floor
Thanks Nick
Old 07-01-2011, 11:44 AM   #9
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
Re: bagging a c-10
look at my build.....nuff said..theres alot of guys out there check some of the builds
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
