07-01-2011, 10:13 AM | #1 |
It'd be alot cooler if you did
suburban rear axle
1991 suburban 350 tbi 700r4. I need a new rear axle. Whats a direct swap? I want the gears to stay the same.
07-01-2011, 01:53 PM | #2 |
Re: suburban rear axle
You have a 8.5inch 10 bolt axle with 31 spline shafts.
You will have to find the gear ratio yourself. You didn't mention 2wd or 4wd, but I assumed 1/2 ton because it has a a 700R4. Get an axle from a 81-91 Sub, Blazer or 81-87 truck. If you go older, you will get a 12 bolt, which has minor mods with the u-joint. Axles older than 88 or so will have 28 splines...not a big deal if swaping the entire axle. parking brake cables should work, if not, swap the entire brake backing plates. |
07-01-2011, 06:39 PM | #3 | |
Also I think 84 they changed the parking brake cable design. I had to do some mods when I swapped out the rear end on my 85 with one from an 82 Burb.
My Projects: 1960 GMC 1/2ton with 305 V6 (daily driver) 1963 Chevy 1/2ton 2wd...converting to 4x4 1967 Suburban 1/2ton 2wd My Girlfriends Projects 1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver) 1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam 1978 Camaro Z28 |
07-02-2011, 11:31 PM | #4 |
Chevys Kick A$$
You gotta figure out what it is by counting the teeth or if your lucky you might still have the build sheet for it in your truck. Which should have a code for your axle. If you want another 10 bolt or you could see about getting the 14bolt 6 lug the put in the light duty 3/4s tons. Late 80's to early 90's should all be the same.
*HOODS is what I answer too* -'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold -'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit -'86 K5 Blazer Silverado 6.2 4" lift 35"s -'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's -'83 Monte Carlo T-Tops. 126,500 Original Miles -LATER I would rather push a Chevy then drive a ford!!
