Diagnosing Suspension Sag - Help Please
I noticed that my truck has developed a sag towards the driver's side. It seems to be even across the front left and rear left tire. I'd like to diagnose it this weekend and get working on a solution.
Aside from checking air pressures, what are some good places to look at for diagnosing the problem? The rear leaf spring does appear to be straightening out a bit. The shocks are ancient and the springs are original to the vehicle. All bushings are also at least 15 years old. My gut reaction is to just buy new springs, shocks, and get a "rebuild kit" for all of the rubber bits... any ideas? (and those replacement parts need to leave it at a stock ride height, sorry ![]() Anbody use this kit for the rubber pieces? http://www.performancesuspension.com...oducts_id=5829 Thanks!
Kurt Instagram: @kurtkphoto 1978 C10 Silverado 1991 Camaro B4C |
Re: Diagnosing Suspension Sag - Help Please
Here's some pics of what i found. The springs were mush at best when these trucks were new. I ended up taking three spring packs appart and mix and matcching the best arches and doubleing up on others. I now have usually less than a 1/4" difference at the fenders when measured. The spring pack I bulit sets higher than with a regular flip kitted truck. I'm at about 4.5" axle to frame for travel (Bump stop removed). I'm thinking I could easly go doen another 1/5" by cutting an overload spring and mounting it on top of the spring pack.
I also replaced the front springs with new stock Moog springs. Original set were cut and I didn't care for the outcome. they seemed like mush too. |
Sure do wish I could photo chop that dent out of my truck
I have the same issue with my truck too but the drivers side is higher than the passenger. All I can think of is to get new front springs and see what I can come up with for the rear?
1977 GMC Sierra Grande |
1LowToy,
Those springs look good; mine definitely don't look that good. I agree that what the truck currently has feels mushy at best. No doubt my dead shocks contribue to that some on the rebound, but the springs are mush. Tires make a big difference in feel, though, and I have those whitewall donuts on there. It's a shame given how good and tight the steering boxes are on these trucks. Looks like I'll just replace all the parts that look suspect in the suspension and see what happens... springs/shocks/bushings.
Shock condition has nothing to do with ride height. You can throw them away and the truck won't get any lower. First, be certain that what you're seeing isn't an optical illusion caused by sagging body mounts, bed mounts etc. My 74 was sagging on the right side but I corrected it with new mounts on the cab and bed. If the mounts are sound then the springs are shot. One last possibility is that the frame is bent in which case nothing you do with the suspension will correct the problem.
check your body mounts, sometimes that rubber has deteriorated so badly makes the truck sag
2008 Silverado Z71 RCSB 1991 GMC Jimmy 4x4 1976 GMC Sierra C15 SWB |
My problem is the same, my driver side is lower, about an inch then my passenger. I'm going to start from the front and work my way to the back. Gonna start by rebuilding my front suspension including brand new lowering springs (current own springs have been cut). Cab mounts after that...
Posted via Mobile Device |
PLease note that if you have a sidesaddle tank your have a more constant weight of fuel on one side. i get sag when i have a full tank.
1985 C10 Custom Deluxe LWB 305/700r4 [ Goldfinger ] ![]() 1999 k3500 crew cab dually 6.5tdi/4l80e |
#10 | |
I took an in depth look up under the truck and there's no one component that seems to be the cause. Looks like I have no choice other than to start doing everything and see if that fixes it. D'oh! ![]()
I jacked up one corner of the rear of the truck and the front straightened out. Then I spent the rest of the afternoon looked all over the place for my floor jack plate.
![]() But really the back springs worked wonders for the leveling. It is a bit stiff but I wanna put some miles on it before I unspring it. I driven it around the block only a few times as I'm still tinkerin |
[QUOTE=1LowToy;4769588]I jacked up one corner of the rear of the truck and the front straightened out. Then I spent the rest of the afternoon looked all over the place for my floor jack plate.
![]() Thats funny right there, I dont care who are. LOL
John 82 Chevy Silverado 350ci/TH350 ![]() |
![]() That sounds like something I would do. And people wonder why it takes so long to get stuff done. I have the tools, I just can't remember where they went!!! |
