Old 07-03-2011, 11:29 AM   #1
rayfinseats
Tech tip: 5 minute shock install
Yesterday I had a broken shock again in the front of my 90 1500. What a pain. I had to use a breaker bar, liquid wrench, cheater pipe, box end wrench and air impact. Since this is the second time a pot hole broke my shock I decided to change something.
I took (2) 1/2 inch grade 8 bolts about 4 1/2" long and cut them to length and drilled a 3/16 hole for a hitch pin clip on the threaded end. NExt time I have to replace a shock all I have to do is pull the pins and pop it in. This is way easier than fighting rusted hard -to-get-to bolts. Since the stress it all on the bolt and not the pin it should work fine. I'm gonna do them all like that on my 83.
rayfinseats is offline   Reply With Quote
Old 07-03-2011, 03:37 PM   #2
SCOTI
SCOTI's Avatar
Re: Tech tip: 5 minute shock install
Or.... you could just put anti-seize on the bolt threads. The road conditions shouldn't cause a shock to break though unless it's bottoming out. Is this on a stock height truck?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 07-05-2011, 01:16 AM   #3
rayfinseats
Yes
Old 07-05-2011, 01:26 AM   #4
MadManAndrew
Very good idea, thanks for sharing.
1955 Chevy 3600 http://67-72chevytrucks.com/vboard/s...61#post8589061
MadManAndrew is offline   Reply With Quote
Old 07-05-2011, 10:56 AM   #5
rayfinseats
I still think it's a good idea. You know how suspension bolts can be. You put anti-seize on your nuts and I'll race you when we replace shocks...I can also pull 2 pins and tilt my box on my 83 to work on the chassis.
Old 07-05-2011, 11:08 AM   #6
SCOTI
SCOTI's Avatar
Deal.
While there's more than one way to get things done, I won't worry about paying up anytime soon because mine will last for years on end w/o failing. Eliminate the failures as part of the install & issues like what you describe shouldn't exist. Less work & cost effective for me. The shocks that were on my 68 Beater w/a 5/7 drop were good for 6yrs of daily use. The shocks on my old 74 w/a 6/8 drop have been in place since 2003, driven daily, & are still chugging along.
Now for a race type application where shocks might be swapped to dial in for track conditions, I could see the benefit.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
