07-04-2011, 09:58 AM | #1 |
Dude...I'm a CHICK
Sterio/ speaker question
Hey yall! Ok, this is something else Ive never really messed with. Before I put my Burb in the paintshop, I removed all sterio, amp and speakers, half of which were rotted and non functional. I really want to put my sterio back in (even tho its cassette, lol) I have a set of 6x9 I just want to put under the middle seat. Im not into thumping and bumping, I just want to be able to hear it, Do I have to install the AMP? or should I be able to get enough volume from the 6x9? Also, if anyone can explain it VERY simply and VERY clearly, how do I hook up the sterio and speakers? I know the sterio basically just plugs in where it was before, but Im using different speakers.
thanks!! junk
~*~*~*~*~*~*~*~*~*~*~*~*~* "The unexamined life is not worth living" -Socrates ~*~*~*~*~*~*~*~*~*~*~*~*~* '71 GMC Suburban 4x4 |
07-10-2011, 08:59 AM | #2 |
78K & 79C Jimmys
Re: Sterio/ speaker question
you may want the amp to get over the road noise
depends on the radio might not have much volume it's important to find the neg/pos with the speakers otherwise they get outa phase and would sound low/no volume/bass if it's not marked you can use a nine volt battery to check for speaker + note the pos on the battery and tap/touch the wires to the speaker when the speaker pushes out, note wher the the pos side is
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
