07-07-2011, 09:00 PM | #1 |
Roto Reuter thats the name...
Help for a disc brake conversion on 8-lug C20
I'm interested in putting disc brakes on my 69 C20 with 8-lug wheels. I have nice 8-lug wheels and would like to keep them. Is there anyway to convert my truck to disc brakes and keep the 8-lug wheels? I've done some reading on the "Drum to Disc Conversion" threads, but didn't see anything unless I'm missing something. I don't want to convert the fronts over to 5-lug wheels and have 8-lug wheels in the rear. What are my options?
Should this be in the suspension section?
~ Dan My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232 My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394 1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt 1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project "Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977 |
07-07-2011, 10:07 PM | #2 |
67-72 parts collector,…
Re: Help for a disc brake conversion on 8-lug C20
There are a few threads here.
http://67-72chevytrucks.com/vboard/s...archid=2435485
07-07-2011, 10:09 PM | #3 |
Another 100 threads here.
http://67-72chevytrucks.com/vboard/s...archid=2435493 If you have more questions,... please feel free to ask.
07-07-2011, 10:49 PM | #4 |
6>8 Plugless........
Your best bet is to find someone parting a 71 or 72 2wd 3/4 ton with discs and purchase the parts you need. Spindles out and proportioning valve should get the job done.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
07-07-2011, 11:12 PM | #5 | |
Thanks guys. Lots of reading to do.
07-08-2011, 06:23 AM | #6 |
Watch out for your cornhole !
Any square body donor truck will work just as well as 71-72 stuff and be much easier to find.
Anything that applies to converting 1/2 ton trucks to discs will apply to a 3/4 ton, as long as you use 3/4 ton parts. The procedure is the same, just different donor trucks.
