Old 07-08-2011, 04:08 PM   #1
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
LSx Swap cost FAQ
Now for the worst part of a LSx swap....The money
If you have a LS swap cost break down or even just a total amount you spent on your LS swap, post up! If you are having problems uploading your file, feel free to PM myself or another Mod.
I'll go first. UPDATED 09/10/11 current total is $2685. I also added all the part numbers I can find. You can easily add $100-150 for shop supplies and things I forgot. There are also a few things that you can probably subtract as I included parts needed to convert to auto trans, hydroboost brakes and power steering.
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 07-08-2011, 04:21 PM   #2
harnalien
TruckincrazY
harnalien's Avatar
Re: LSx Swap cost FAQ
Ok, I don't feel tooooo bad considering mine includes the cost of the cam, cam swap related parts, and the labor to do it.
My build thread - '84 2wd w/ a 6.0 swap
http://67-72chevytrucks.com/vboard/s...d.php?t=433595
harnalien is offline   Reply With Quote
Old 07-09-2011, 12:44 AM   #3
usmcchevy
usmcchevy's Avatar
Post up then!
Build thread
LSx Swap FAQ index
Old 07-09-2011, 01:25 AM   #4
harnalien
TruckincrazY
harnalien's Avatar
Originally Posted by usmcchevy View Post
Post up then!
you asked for it
keep in mind, the price for the cam install includes having to buy new heads, head gaskets, and bolts because my heads on my original motor were discovered to be bad. Also, the miscellaneous includes labor chargers for help I needed to keep things moving. I still have to pay for exhaust and some fine tuning next week. It's sickening looking at the numbers, but maybe this will give someone a real picture of what can go wrong and prepare them for it. There is easily $2500 that could be removed from this if I hadn't swapped cams. Ok, enough excuses, lol!
Old 07-09-2011, 10:20 AM   #5
Clyde65
Clyde65's Avatar
Harnalien, the only difference in yours and mine is you had engine work, I didnt.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 07-09-2011, 03:22 PM   #6
Super73
Super73's Avatar
Ok, do I give you the first build, or the second
First:
347 ci motor forged internals, machine work and I assembled it $3,800 in the shortblock
Heads and cam were bought from a buddy of mine, they were used to go 10.7x in his 4th gen $600
CTS-V lifters $250
Push rods $150
Head Studs $225
Super Victor intake with spacer and Dominator throttle body $1,100
Misc covers, and accessories I had from other motors
Wiring harness (brand new gm unit, I deleted a bunch of wires) $250
Headers $450
Exhaust $150
PCM $75
(2) -8 feed lines, dual walbro fuel pumps, misc t-connectors, aftermarket fuel rails, regulator, 60lb injectors, about $1000
4L80E with aftermarket converter $1,500
HPtuners (I already owned this from doing tuning on the side and have unlimited licensing for 99-02 F-body, so this does not get included).
Additional speed density and 4L80E segment swap through HP tuners $100
$9,650.. I am sure I am forgetting a coule things so let's just call it an even $10,000..
Now, for the new motor
Sold old shortblock, heads, cam, head studs for $2,750
Retained the Super victor, fuel system, headers, accessories, most covers, lifters, push rods, anything I could.
New:
Shortblock, again machined and parts, I put it together $5,000 (LS3 block, 4" callies crank, Weisco pistons)
AFR 225 heads with light weight intake valves $2,500
New cam $400
Wiring harness extension, LS3 front cover and valley cover, LS2 timing set $300
Upgraded rocker arm trunions $225
Another $6,000 in the new motor
Sold the 4L80E bought a build glide total out going expense $1,300
Have changed gears $500 (rear end weling work ect).
N20 system $1200
Let's just say there is a lot of money tied up in my old truck. All to hopefully go 10.70-80 on motor and deep 9's on the bottle.
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 07-11-2011, 12:07 AM   #7
softballnrd27
Always a work in progress
softballnrd27's Avatar
Here is my list.
It also includes all the drivetrain/suspension stuff that I will be purcahsing as well.
THE 1!!.pdf
USMC Retired
Never trust a man who can't laugh at his own fart!
2010 Silverado Crew Cab
73 SWB 5.3/4l80e
Build Thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=695168
softballnrd27 is offline   Reply With Quote
Old 07-11-2011, 03:09 AM   #8
skoffice
skoffice's Avatar
Anything marked with an "*" is a part I purchased used
*6.0 and 4L65 $2300
Clay Smith Cam, lifters, springs, pushrods $700
*LS1 intake and TB $80
Pro Products Fuel rails $100
Walbro Fuel pump and Pro Products reg. $300
Fuel Lines and fittings $250
*Pacesetter F-Body Headers $200
Exhaust with Dynomax Bullets and Xpipe $400
*Howe Power Steering pump/pulley/bracket/res/lines/hydroboost $680
Belt $30
ARP head, rod, and balancer bolts $210
Roller Rockers $200
Double Roller Timing $200
Head Gaskets $60
*LS3 injectors $60
Afco Radiator $320
Spectre Air Filter/Silicone elbows $45
*Spal Fans $150
Ebay Fan controller $50
Howell Tuned Computer $300
*Abaer Valve covers $300
Oil Pressure Sender adapter $15
Fluids $140
Driveshaft $190
Shift Linkage $45
Throttle Cable $40
*CFR Trans cooler/Lines $250
Radiator hoses $40
NGK plugs and stock wires $40
180* Thermostat $15
*Autometer Electric Speedo $90
Summit Deep Trans pan $170
Harness - 1,000,000 hours converting the stock one HAH!
Traded my truck pan to a buddy for his LS1 pan
Ported my own heads and oil pump
Did some trade work for a 3600 Performabuilt stall
My engine/trans had 10k miles on them so no need for any other new parts. It should be a good solid 430 horse the way it's built, no worries about failures. It runs strong.
I must be forgetting some nickel and dime parts...I've never added it up before and it's kind of scary haha but so far that's:
$7970
1964 C10 Shortened Shortbed Cammed LQ9 P&P
1967 C10 Trophy Truck BB 438 (soon to be worked on again)
skoffice is offline   Reply With Quote
Old 07-11-2011, 03:25 AM   #9
harnalien
TruckincrazY
harnalien's Avatar
Ok good, I'm not alone
Old 07-11-2011, 12:54 PM   #10
Super73
Super73's Avatar
I honestly think a 5.3 could be put in a truck for under $2,000 if wise choices were made and deals were found. I have seen complete running 100k mile 5.3 with 60E's go for $750.
I have seen truck pcm and harness combos unmolested go for under $250. Just take your time rerouting and pulling wires you don't need. There are diagrams all over the net.
Motor mounts are cheap maybe $100 in them.
Modified factory tank with an external walbro and remaining fuel system parts $200 (vette regulator/misc line)
Exhaust work tying a factory manifold in to existing exhaust $150
Find a drive shaft in the junk yard if yours does not fit $75
Find a local tuner to get rid of vats and other smog related junk (if they are like me, I'll do that for $100 since it literally takes 5 minutes to do).
Piece of 4" exhaust tube from your local exhaust shop to put your filter on $25
K&N cone filter $50
Right there is $1,700, leaving $300 in misc unseen items. It could be done. The problem isn't doing it cheap for stock, none of us go totaly stock. We are our own worst enemy!!
Old 07-11-2011, 12:59 PM   #11
softballnrd27
That is the part that keeps getting me. I want to have my drivetrain built up to handle the extra HP but I also want to add extra HP to the motor via bolt-ons. I chose to get the drivetrain/suspension right 1st.
USMC Retired
73 SWB 5.3/4l80e
Build Thread:
Old 07-11-2011, 02:11 PM   #12
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Mine (hopefully this works)
$79xx for all my goodies. This is not stock, and I have included a few other non motor things that occurred during that timespan. Mine would be well under 7 without things like the seats etc that I added./
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 07-11-2011, 06:07 PM   #13
Clyde65
Clyde65's Avatar
Ok, I do not feel bad any longer, I thought I was breaking the bank at $4K.
Clyde65
Rebuild of Clyde
support our troops!
Old 07-14-2011, 10:42 PM   #14
awhite4557
awhite4557's Avatar
I have a 71 Chevy Short Wide Bed PU that I swapped a 5.3 LS1 and 4L60E trans into. Here is a cost breakdown for my swap.
1950 Chevy 3100 Ramp Bed 1-ton
http://67-72chevytrucks.com/vboard/s...d.php?t=749386
1965 Chevy Step Side
1971 Chevy Short Wide Bed
http://67-72chevytrucks.com/vboard/s...d.php?t=277191
1971 Chevy Chevelle
1972 Chevrolet C-30 1 ton
2002 Winnebego Class A MH Ford E-550 Chassis V-10
2005 Dodge Ram 2500 5.9 Cummins
2008 GMC Denali
2020 Jeep Wrangler Unlimited Rubicon
awhite4557 is offline   Reply With Quote
Old 07-19-2011, 12:07 AM   #15
dan42
dan42's Avatar
Nice breakdown. It's giving us guys that are thinking about it an idea of the costs. Keep 'em comin'.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 08-15-2011, 04:52 PM   #16
aggie91
I'm just glad to be here!
aggie91's Avatar
x2
I like the break down with the part numbers.
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 08-30-2011, 09:22 AM   #17
tucsonjwt
I think the original question concerned gas mileage, at least in part.
I have owned many 5.3 and 4.8 new GM trucks and SUVs. In those new vehicles, with very careful driving, I got 17 mpg city and 23 mpg highway, whether it was 4.8 or 5.3. Rear axle ratio is important -3.23 best for mpg, 3.73 worst. However, my latest new vehicle was a 2010 GMC Sierra Ext. Cab with 4.8 and 3.23, and that got 15.5 city and 19 highway. If I did more conventional (less stop and go) driving I think I would have gotten 17/23 on that vehicle also. I am very anal about keeping track of mpg, and drive like your grandma (not the one from Pasadena.)
Some practical considerations would rule out the LS swap for me. In AZ you are not allowed to swap engines according to emissions rules, even if the replacement engine produces less emissions. You must have factory original engine and all factory smog components in place. Some say they get through emissions with modified/newer engines, but I always get super inspected when I go to emissions and would never pass - plus I think there are technically fines for this kind of mod.
As stated above, mpg would not improve much for a swap, assuming you are comparing the engines in a lightweight 1/2 ton truck. Most old squares get 10-12 city, 13-15 highway - but I think you can do better with a V6 and open rear end and overdrive transmission - especially highway.
I only drive my truck about 3000 miles per year, but it is a 454/SM465 3/4 ton beast with a dump bed conversion, so it is suited for my limited purpose as is, even if it is only 8-11 mpg city - which is the only place I drive it. It sits idling at stop lights more the it drives down the road.
As most forum members posting here know, the greatest cost in owning these old squares is all of the non-drive train components - over time. All of the electrical/mechanical/interior trim parts add up over time. While this is ultimately true for any vehicle, it really makes more economic sense to buy a newer (or new) vehicle and limit your other expenses. Modern trucks with LS engines in decent shape go for $7-10K and you won't have to put much money in them if you get a good one.
tucsonjwt is offline   Reply With Quote
Old 07-19-2011, 11:37 AM   #18
Shon
One thing that made me go the LSx route was the HP/TQ and my hope for MPGs in comparison to a very hot 350 or mild 383 and I would still have TH350.
I felt like the LSx swap would offer more power and overdrive than I could get for the money if spent on a 383.
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap
Shon is offline   Reply With Quote
Old 07-19-2011, 11:51 AM   #19
faribran
the route i have chosen to to NOT KEEP UP WITH TOTALS...... :-)
faribran is offline   Reply With Quote
Old 03-19-2014, 09:13 AM   #20
solidaxel
solidaxel's Avatar
YES, that is the way I went.
Using many years of experience and buying what was needed to change the engine and transmission. Job complete wallet lighter!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 08-01-2011, 02:08 AM   #21
raticl511
The LS swap into my 4X4 got put off to build my daughters 72 nova. I ended up installing a 5.3 and a 700r4 into her car first. I contacted a company called Wait4me performance for the wiring. http://www.wait4meperformance.com/.
At $360 was by far the best deal on the computer tune and harness modification I found. I sent them the computer and the stock harness and they trimmed the unneeded wires and tuned the pc to my setup, ie: cam, intake, trans ...
I sent off nearly every wire under the dash and in the engine compartment from the doner truck and when I got it back, the harness I was to use was seperated from the rest with easy to read labels. That 18 months ago and I just checked his website and it looks like his price hasn't changed. @ $360 nobody else comes close.
raticl511 is offline   Reply With Quote
Old 01-09-2014, 12:50 AM   #22
stevenbear72
stevenbear72's Avatar
That sounds like a really good deal. I may have to go their route and have them re-work the harness I already have. Thanks for the info bud
68' Cst10 w/69 front, 5.3/4L60e swap, 12 bolt 4.11's
Project "Huckleberry"
68 GMC K1500 1/2 ton L83/6L80e
stevenbear72 is offline   Reply With Quote
Old 08-09-2011, 04:05 PM   #23
greasemonkey71
when can i get motor mounts for a 5.3 to bolt up to 71 c10
and a tranny cross member?
greasemonkey71 is offline   Reply With Quote
Old 08-09-2011, 04:51 PM   #24
Clyde65
Clyde65's Avatar
see your other post
Clyde65
Rebuild of Clyde
support our troops!
Old 08-30-2011, 10:39 AM   #25
thepunisher
thepunisher's Avatar
Great thread usmcchevy!
Blayne
thepunisher is offline   Reply With Quote
