Old 07-10-2011, 11:49 AM   #1
sethv
sethv's Avatar
Rear end gears and transfer case speedo gear
Hey guys. I need to find the correct speedometer gear for my truck. But first I'll need to figure out my differential gear ratios.
Using this calculator, http://www.apexgarage.com/tech/gear_ratios.shtml, and doing roughly 2100 RPM, I was doing 55 (passed a sign that tells you your speed), so I put this info in:
30.5" tires
4th gear's ratio of 1
And I assumed my rear end was 3.54, but it would also be close if I chose 3.42. (for the final drive)
So which was more common? I know it's gotta be one of those two, but I cannot pull my diff cover (I can't afford the extra fluids as of right now).
Also, which color was the speedometer gear for the rear ends? The junkyard told me they were color coded and to let them know which one I needed.
Thanks guys and sorry if I'm missing anything.
1981 K10 Scottsdale
305 ci | TH350 | NP208 |
60k miles
sethv is offline   Reply With Quote
Old 07-11-2011, 09:49 PM   #2
79BIG10
I'm back with 2nd truck!
79BIG10's Avatar
Re: Rear end gears and transfer case speedo gear
Look here for a great article on getting the rear axle gears found out. http://73-87.com/7387garage/drivetrain/speedo.htm
1979 Chevrolet Bonanza Big10 "Tootsie Roll"
1985 Chevrolet Silverado (wife's)
Member of the Southern Bowties Club
"Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson
79BIG10 is offline   Reply With Quote
Old 07-12-2011, 12:38 AM   #3
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Use this calculator.
Find the best whole number combo for gears.
http://www.tciauto.com/tc/speedo-info
Gerardo a.k.a. Mad Chemist
Silverado XST videos
