Old 07-11-2011, 06:37 PM   #1
HarrisonTX
Aluminum Fuel lines, and todays gas.
I have a Holley Truck Avenger that I am ready to bolt on.
My truck has an exsisting hard line, going to the edelbrock carb. I really like the idea of a hard line.
Due to the connections, I'm going to have to bend an entire new fuel line.
I'm worried about the 10% ethanol corroding the aluminum. Should I worry about this?
'69 custom/camper
'74 260z 302 chevy/tko500 swap in progrss
'79 Malibu 355 all forged 4 speed car.
'86 k5 blazer
'06 Duramax
HarrisonTX is offline   Reply With Quote
Old 07-11-2011, 08:37 PM   #2
Pyrotechnic
Pyrotechnic's Avatar
Re: Aluminum Fuel lines, and todays gas.
I would just go with the standard steel line, same as what came on it. All the reading I did on this topic said that aluminum line will get brittle from vibration over time. I have no personal experience with it but with other options readily available I steered clear of the aluminum.
1977 GMC Sierra Grande
Pyrotechnic is offline   Reply With Quote
Old 07-11-2011, 09:31 PM   #3
HarrisonTX
I feel like a dunce. I didnt consider steel. Thanks man. Problem solved.
'69 custom/camper
'86 k5 blazer
'06 Duramax
Old 07-11-2011, 10:27 PM   #4
qu1cks1lver56
qu1cks1lver56's Avatar
Don't burn 10% ethanol gas if you can help it. Makes your gas mileage go way downhill, loses octane faster, and it deteriorates any rubber hoses, gaskets, powervalves, etc it comes in contact with.
Look here to see if you have any 100% gasoline in your area
http://www.pure-gas.org/
qu1cks1lver56 is offline   Reply With Quote
Old 07-11-2011, 11:06 PM   #5
76stepsidechevy
I wish I could still find 100% gas around here.
76stepsidechevy is offline   Reply With Quote
Old 07-12-2011, 05:15 PM   #6
INSIDIOUS '86
INSIDIOUS '86's Avatar
most fuel today is 10 percent ethanol
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
