07-12-2011, 12:11 PM | #1 |
10 bolt knuckles on a 44
can i use 3/4 ton knuckles from 10 bolt front on a dana 44 front
07-12-2011, 12:22 PM | #2 |
Real Projects never die
Re: 10 bolt knuckles on a 44
as long as its the later small hub 44 everything from knuckle out should interchange if i remember right.
Ill put it this way, ive got a few lawn ornaments My name tag says Ryan KansasTwister On other forums
07-12-2011, 12:44 PM | #3 |
cool its the later 70's model dana 44 out of like a 78 or so i think had the standard lockouts like all fullsize 4x4's in the 80's
07-12-2011, 07:00 PM | #4 |
If you swap EVERYTHING from the knuckles out it will be fine. I had Dana 44 external lockouts on a temporary 10 bolt till I swapped the 44 in. Actually used the 10 bolt knuckles with the 44 hubs rotor etc on it.
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 6” lift 1999 GMC Yukon 350/4L60 4" SAS |
07-13-2011, 07:17 AM | #5 |
that is exactly what i want to do is use the 10 bolt knuckles an 8 lug outers on the 44 which was 6 lug
07-13-2011, 08:31 AM | #6 |
Good info. I just put a 4.10 10-bolt 8-lug in my Jimmy. I have a Loc-Right for a Dana44 and want to swap one in. I was looking for an 8-lug but I guess any Dana44 will do.
07-14-2011, 12:59 PM | #7 |
you can swap just the spindle out to get the 8 lug stuff the reason i wanted to swap the knuckle out is i bought a 8 lug ten bolt with good ball joints an 4:10s an i have a dana 44 with bad ball joints an 4:56 gears to match my rear
