Old 07-13-2011, 05:22 PM   #1
kieth
kieth's Avatar
Blazer Large Fuel Tank Install
I had seen everyone elses Blazer tank install and I to had reservations about how low it hung down so I tried something a little different with my rear crossmember so the tank could sit higher. Anyone else done anything like this........???
modified crossmember
http://kieth.smugmug.com/Trucks/66-G...005088_DrSmCmf
How high the tank sits above the frame:
http://kieth.smugmug.com/Trucks/66-G...005429_gWBxmmr
where we a locating a angle iron bracket for extra strength:
http://kieth.smugmug.com/Trucks/66-G...003673_7qBM5tJ
we are welding the nuts for the fuel tank to the bottom frame flange, since it is really hard to get to and will be the last thing installed. The bolts for the tank straps are also being welded in to facilitate installation. Pictures will follow. tomorrow on this part of the install.
Click on each picture to see where we are installing permantenty mounted bolts and nuts for the Fuel Tank.
http://kieth.smugmug.com/Trucks/66-G...477709_NK7N8DW
kieth is offline   Reply With Quote
Old 07-13-2011, 08:55 PM   #2
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Re: Blazer Large Fuel Tank Install
Thanks for sharing.
I saved some of your pics for future reference.
I have a 79 suburban tank I hope to use.
I also was concerned about how low it would hang.
Your images I saved:
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 07-14-2011, 08:45 AM   #3
kieth
kieth's Avatar
I took some more photos this am, will post them later after we get the rear crossmember installed, the bumper brackets, the fuel tank and the bed on so we can see how low it sits and how stable the bed is. I can tell you that with just the bed wood in and installed on all the crossmembers, even without the inner rear fenders installed the bed is rock solid even with the center of the original crossmember missing.
Kieth
Old 07-19-2011, 01:35 PM   #4
LostMy65
LostMy65's Avatar
How's it going?
I'm getting ready to do mine.
If you don't mind, I'll post my progress here so the info is consolidated for others.
Thanks,
Robert
