Old 07-16-2011, 01:58 PM   #1
wilberweb
wilberweb's Avatar
55 Chevy 3100 1/2 ton chevelle rear swap
Hi, Guys I have a question on a 69-78 Chevelle Rear end I am installing in my 55 Chevy 3100 second series truck. I installed a camaro front. I got a great deal from a friend so I had to take it, I wanted to keep the rear a camaro so as to not get confused when I need to order parts, keeping things consistent.
I installed the rear end on my stock rear leaf springs. This Chevelle has some bushings towers on the top of the rear end for a stabilizer.
my plan is to use the stock arms and mount a bracket to the frame with the rear leaf springs.Has any one done this with stock leaf springs? or should I just cut the bushing towers off, and just use the stock springs.Also how is the ride with the stock springs and the camaro? here are some pictures of what I am up against.
-Larry
wilberweb is offline   Reply With Quote
Old 07-16-2011, 02:11 PM   #2
Kim57
Kim57's Avatar
Re: 55 Chevy 3100 1/2 ton chevelle rear swap
The chevelles had a triangulated 4 link with coil springs which eliminated the need for a panhard bar.
If your running leaf springs I don't think the bars will do anything to stabilize the rear but I may be wrong.
Kim
Kim57 is offline   Reply With Quote
Old 07-16-2011, 02:45 PM   #3
tmoble
you don't need the ears and the links that go on them when you're using leaf springs. the leaf springs locate the rear just fine. You can use a hacksaw type blade in a Sawzall to amputate the ears. no big deal.
tmoble is offline   Reply With Quote
Old 07-16-2011, 05:21 PM   #4
wilberweb
wilberweb's Avatar
Thanks guy's
That's what I suspected, I was leaning that way. I'll cut the ears off grind it down.
-Larry
