Old 07-18-2011, 08:03 PM   #1
kelsfine69
18 Till I Die
kelsfine69's Avatar
1987 Diff same as 1988??
Pretty sure I Know the answew but I thought Id check anyway. 1987 was the last of the squares as everyone knows. Is the diff the same or close as a 1988. I can get an 1988 rear diff for 100 bucks so the price is right but not if it dont work. I need a 3:42 Posi cause mine is Hoop'd.
2011 GMC Acadia
1969 GMC BBC LS7
2007 GMC Crew Duramax
1987 Camaro Iroc 350 Tuned Port Injection
42000Km
1987 Chevrolet Silverado 350 TBI
1987 Chevrolet Silverado 350 TBI(yes 2)
Take me drunk, I'm too home...
kelsfine69 is offline   Reply With Quote
Old 07-18-2011, 08:35 PM   #2
SSC's76
No No
SSC's76's Avatar
Re: 1987 Diff same as 1988??
88 is slightly longer about an inch on either side.depending on your wheel backspacing may not effect clearances usually doesent. the only thing I dont recall off hand is if you would need a different u joint. for the price might be a good option unless the new diff is a grenade lock.
1976 Custom Deluxe SWB Med FMB.3/4 Drop.
Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out.
1997 K1500 ext cab 5.7 stock except muffler
SSC's76 is offline   Reply With Quote
Old 07-18-2011, 11:55 PM   #3
Pop's C-10
Pop's C-10's Avatar
You may be able to swp tha whole axle, but tha posi unit won't swap...if that's what you mean...28 spline vs 30 spline..
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Pop's C-10 is offline   Reply With Quote
Old 07-18-2011, 11:58 PM   #4
USSkoval
Is it from a new body style truck, or an '88 Burb? The new body style axle would need the spring perches and shock mounts cut off and welded back on in the correct spot.
-Andy
'77 K5 Blazer
'78 K10 Shortbed
'78 C20 Suburban
'79 K30 Crew Cab Dually
'84 C10 Short Stepside
'88 K20 Suburban
USSkoval is offline   Reply With Quote
Old 07-19-2011, 11:55 PM   #5
67_SS396
The 87 should have a 30 spline carrier if it's original to the truck.
Fawker Fab three seater rock crawler buggy 498 BBC/SM465/203/205 doubler, propane, 5.13's, 42" PB Rockers
'66 C10 - The new hot rod
'77 3+3 Dually - 12 valve 4wd conversion tow rig project
'28 Ford 2 door sedan street rod
RevLimit Offroad
"Hang on beer, we can do this."
67_SS396 is offline   Reply With Quote
Old 07-22-2011, 12:34 PM   #6
kelsfine69
18 Till I Die
kelsfine69's Avatar
Yes all original..Are 3:42 non posi common to find?
2011 GMC Acadia
1969 GMC BBC LS7
42000Km
Old 08-11-2011, 10:46 AM   #7
kelsfine69
18 Till I Die
kelsfine69's Avatar
does anyone know?
2011 GMC Acadia
1969 GMC BBC LS7
42000Km
Old 07-19-2011, 07:06 AM   #8
motornut
78K & 79C Jimmys
motornut's Avatar
i have an 88 square burb ,and it's the same as my 87 burb .....not like my 89 burb the front changed
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 07-19-2011, 10:42 AM   #9
kelsfine69
18 Till I Die
kelsfine69's Avatar
Yea thought so..My 3:42 gov has seen better days and I would like to swap in a whole diff rather than tear it apart. If i cant find another what would be the way to go to get a 3:42 posi in a 10 bolt without going back to the Gov-bomb? Mayby I should look for a 3:42 Non Posi?
2011 GMC Acadia
1969 GMC BBC LS7
42000Km
Old 08-12-2011, 07:10 AM   #10
motornut
78K & 79C Jimmys
motornut's Avatar
88 is 3.73
duno bout the 87
John
Old 08-11-2011, 11:46 PM   #11
67_SS396
3.42 is quite common in the 88-up.
RevLimit Offroad
