Old 07-18-2011, 09:17 PM   #1
Buzzman
Buzzman's Avatar
Speedo cable w/ cruise...
Hey There.
First post, hopefully of many. I've just gotten my second square-body, a 79 Cheyenne SWB. Goodwrench 350, th400, stock stock stock other than that. Among a few problems is the broken speedo. This truck has cruise (which I don't plan on using), and thus the two separate cables - one from the gauge to the cruse thing on the inner fender, and one from the cruise to the tranny on the driver's side. My question is whether or not I can bypass the cruse all together and use one standard-length cable from the gauge to the tranny. Anyone done this? Thanks.
79 C10 Cheyenne SWB Daily Driver
Buzzman is offline   Reply With Quote
Old 07-18-2011, 09:22 PM   #2
Restrorob
The One And Only !!!
Restrorob's Avatar
Re: Speedo cable w/ cruise...
Sure it can be done, Just buy the cable for your same truck without cruise.
And..... If I don't do it someone else will !
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
Old 07-18-2011, 09:25 PM   #3
Buzzman
Buzzman's Avatar
Great, thanks for the reply. How about removing the whole cruise unit? Is it just a matter of plugging the vacuum lines to the carb? There's a bunch of crap going on back there and I'm a little hesitant...
Old 07-18-2011, 09:37 PM   #4
Restrorob
Restrorob's Avatar
Just remove all the parts and block the vacuum ports on the carb/intake and tape the wire plugs to prevent shorting on anything, I've removed them and added them over the years......
93 Jeep XJ
88 Buick La Sabra
Toys;
97 GMC Ext. Cab
Old 07-18-2011, 11:40 PM   #5
Buzzman
Buzzman's Avatar
Great, thanks! I'll let you know if I ruin anything
Old 07-19-2011, 11:48 AM   #6
jimbonice
jimbonice's Avatar
If you do want to run cruise, it is not that expensive to fix. When I bought my 1977 it had the cruise unhooked with one single speedo cable. I bought a new cruise transducer from rockauto and the proper speedo cables and it has been good ever since.
jimbonice is offline   Reply With Quote
Old 07-19-2011, 09:52 PM   #7
Buzzman
Buzzman's Avatar
Ok, got the cable hooked up, drove around the block... a miracle! It's alive!
Isn't it great when things work? Thanks for the help.
