07-19-2011, 09:04 PM | #1 |
Temp Gauge not working
Well I think the gauge may not be the problem, but it never moves when I'm driving it. the gauge will peg hot when I ground the wire, So I replaced the temp switch, didn't fix it. I tested the temp with a multimeter, put the +lead on the + side of the batt, then the -lead on the spade connection on the temp switch, read 12v. From what I've read this means the switch is short circuited and no good, but then shouldn't gauge peg hot when ever the wire to the gauge is hooked up? It doesn't.
'68 C10 LWB 6.2NA/NP833 3.73's |
07-20-2011, 02:17 AM | #2 |
Hand Crafted C-10
Re: Temp Gauge not working
Gunna move you to electrical...maybe they can help.
07-20-2011, 06:54 AM | #3 |
Java Mechanic
Check impedance from the spade to a good engine ground both hot and cold and see what you get.
Keith 11 Lincoln MKT -- Momma's wagon 13 G37xS -- middle age crazy car 68 C20 Fleetside -- RIP Decorating the whole town up at a cost of $27 .... |
07-20-2011, 08:46 AM | #4 |
Msgt USAF Ret
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
