07-20-2011, 09:30 PM | #1 |
C-Notch 87.
I need to cut a small part out of a brace that goes across the bottom of the bed. The c-notch won't slide under the bed. How do I cut it out without removing the bed? I don't think I can get a torch in the area. It is an 87.
07-20-2011, 10:24 PM | #2 |
67-72 parts collector,…
Re: C-Notch 87.
Can you just loosen the bed bolts and then just block the bed up with 4x4's or something?
No need to take it completely off.
07-20-2011, 10:39 PM | #3 |
Re: C-Notch 87.
07-21-2011, 10:49 AM | #4 |
Happy to be here
Re: C-Notch 87.
Like lolife99 you can unbolt the bed and lift one side at a time by yourself. It's much easier if you remove the bed completely as long as the bolts aren't rusted. Either way, I would raise the bed before cutting a brace above the C-notch
07-21-2011, 05:27 PM | #5 |
Re: C-Notch 87.
Thanks, that will be my winter project.
